Page 1 of 1
[ 15 posts ] |
| Author |
badwaxcaps
Post subject: Zenith 4K310 knobs wont come off. Posted: Jul Wed 04, 2012 9:51 pm |
Joined: May Thu 26, 2011 5:58 am Posts: 864 Location: Sterling- A city in Northern Virginia about 20 miles outside of D.C
This is driving me nuts. The knobs on this set are insanely tight. They won't come off. Tried everything from gently prying to brute force. I need to remove the chassis so I can work on caps and such but these knobs are preventing me from pulling it. Are there repro knobs available? If so I may cut these off as they are not in great shape anyways. I just don't like resorting to destruction as a solution.
_________________ "Those are my principles. If you don't like them... well I have others"
| Top |
JerryHawthorne
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Wed 04, 2012 10:35 pm |
Joined: Feb Sun 24, 2008 4:21 am Posts: 2087 Location: Sedona, AZ
Is this an AC/DC radio? If so, I have come across a couple of these and there is a retaining clip of some type as I recall on the knob or shaft that prevents a user from taking off the knob and subsequently grabbing a "hot" shaft. I don't recall how I got the chassis out but it seems in my muddled memory that one had to loosen the chassis and pull from the rear. Needless to say, I goes back in easily but none the less, I left those little devils off. I could be totally wrong.
Jerry
_________________ A friend in need is a pest. Bill Slee ca 1972
| Top |
badwaxcaps
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Wed 04, 2012 11:23 pm |
Its odd because the one I got to come off a little wont slide back on either. It came off about 1/8" and thats it. Its like they are glued in place. This is a four tube battery set.
| Top |
joybird
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Wed 04, 2012 11:32 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4233 Location: Wilmington, NC 28412 USA
As you know those Knobs are very fragile.
What I have done with Good success is
Set the Radio down on the Knob tops. Spray shafts under skirt with WD-40, Liquid wrench or OIL what ever you have.
Let it set 5 minutes or so , allowing the lube to work down the shaft into the knob.
Repeat a couple times wiping off excess each time.
Then Set Cabinet on its back , take a plastic screwdriver Handle (Nut Driver Handle , and tap on the TOP of each knob GENTLY, shocking the knob on the rusted shaft.
Then you must take 2 pieces of wood shims that will fit under the Knob between skirt and the Radio cabinet face. Doing one Knob at a time.
Tap them in until both are SNUG
Then put a strip of hard wood across the end of the 2 wood shims and tap on it so both Shims receive the same amount of force.
Do this slow and gentle as the skirts are easy to break.
If you applied enough WD-40 or the such they should pop loose.
Just take your time.
I have used this many time with success every time.
Hope it works for you
Let us know
Regards, Bob T
| Top |
K4YDO
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 3:27 am |
Joined: Nov Mon 28, 2011 2:55 am Posts: 132 Location: Florence, SC 29506
badwaxcaps wrote: This is driving me nuts. The knobs on this set are insanely tight. They won't come off. Tried everything from gently prying to brute force. I need to remove the chassis so I can work on caps and such but these knobs are preventing me from pulling it. Are there repro knobs available? If so I may cut these off as they are not in great shape anyways. I just don't like resorting to destruction as a solution. Set screws?? Ed
| Top |
badwaxcaps
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 3:41 am |
Nope.. no set screws. I have worked on over 50 radios and never came across anything like this.
| Top |
glasdave
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 5:35 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
Stick it in the freezer for a coiple hours.Then use the wedge method.
_________________ I move the world just one step on...
| Top |
VintageTunes
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 1:27 pm |
| Member |
Joined: Nov Tue 06, 2007 4:21 pm Posts: 2135 Location: Twin Falls, Idaho 83301
Its a very common issue with this style of knob on those Zeniths as well as the 5-R-312
There is no one out there making these knobs as a reproduction. A few guys make similar ones but these, as you know, have the long shafts that go into the bakelite and no one that I know of make the correct ones.
after breaking about 6 of these trying to get them off I had a fellow ARF member (KENG) tell me how to do it. You reach through with a soldering iron and heat up the metal shaft. Let is set on there as long as you possibly can without melting the knob. Then she just slides right off. I tried it and it works slick. I have taken off 4 sets since then and I have yet to damage any of them.
Good Luck
~jeff~
_________________ TESLA !! (the man....not the band)
| Top |
blacksmith
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 1:37 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1012 Location: Shelby Township, MI 48316
If they are the small diameter shaft knobs, I make them. Just haven't put them on my web site yet. Ed
_________________ Blacksmith
www.renovatedradios.com
| Top |
VintageTunes
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 2:41 pm |
| Member |
well hell Ed, If thats the case, I'll take three pair!
I didn't set out to mislead anyone. I am glad you posted that
~jeff~
| Top |
badwaxcaps
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 8:04 pm |
Jeff.. I can just barely see the end of the shaft for the tuning knob but the volume is inaccessable. Ed.. can you post a pic of the knob you have?
| Top |
blacksmith
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Thu 05, 2012 10:58 pm |
| Member |
The broken knob I used for a model looked like the hole was a stepped affair. Not sure if that is correct or it was worn that way. I filled the back and drilled a 1/8" hole for the shaft. Is that the correct size?
I don't have a picture yet, I still have to mix the color and pour the first few knobs, but I should be able to get them made by Saturday.
| Top |
turkcowan
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Fri 06, 2012 2:25 am |
Joined: Jun Sat 30, 2012 9:14 pm Posts: 49 Location: Boston, MA
You probably already tried it but I've also found the old zenith knobs to be really tight. I slip some twine behind them, one on bottom, one on top, so I can pull evenly from both sides. Seems to work. Good luck.
| Top |
badwaxcaps
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Fri 06, 2012 2:34 am |
Ed, these knobs look like little hard hats and have a shaft attached to them. The shaft is about 7/16" in diameter and at least 3/4" long from what I can see. Quite resilient as well.
| Top |
blacksmith
Post subject: Re: Zenith 4K310 knobs wont come off. Posted: Jul Sat 07, 2012 2:00 am |
| Member |
Doesn't sound like what I'm making. These are flat on the bottom with just a hole in the center. No part of the knob extends into the radio cabinet.
| Top |
