It is currently Jan Wed 24, 2018 6:43 am
Post New Topic Post Reply  [ 37 posts ]  Go to page Previous  1, 2
 Post subject: Re: Sparton 15 restoration
PostPosted: Jun Mon 19, 2017 12:00 pm
Expanding foam: no reason to believe it would be conductive, but I'll check. When drying, it shows no sign of attacking anything else. Once dry, it is inert.
I don't have a big database on pot cleaning....only two basic observations:
WD40 does not fix all bad ones, but has never damaged one
I tried IPA only once or twice on older pots. When one got damaged, I never used it again
-Mark http://pixellany.com
PostPosted: Jun Mon 19, 2017 5:57 pm
I've rarely had isopropyl alcohol attack anything, though I left an old toothbrush in a jar with alcohol in it over the weekend. It did mess up the toothbrush head after 48 hours of soaking in the stuff. Never thought that would happen!
Everyone has their preference for cleaning old pots. Use whatever works best for you.
Kinda doubt the expanding foam is conductive, or would attack the outside of the encapsulated capacitors. Never hurts to check. Actually, I like your idea of using it. You may be one of the first restorers to try that technique.
Keep up the good work Mark.
Mitch
PostPosted: Jun Mon 19, 2017 7:00 pm
IPA isopropyl alcohol.
I was wondering why you were using beer to clean a volume pot :wink: :lol: .
Outstanding work on that chassis.
Consider me a straw in your haystack of success.
PostPosted: Jun Mon 19, 2017 7:59 pm
I have friends from India, they beautiful people and I feel fortunate to know them. But I've told them I do not like Indian food, sorry. And IPA, Indian Pale Ale, is not my favorite either. I'm a Guinness Extra Stout drinker.
Just to be certain I'm on the same page with you, the re-stuffing is basically cosmetic? The old cans could have been left disconnected but attached to the chassis and the new caps placed elsewhere if there was room to do that?
Notice the question marks, because I'm interested in learning here if there is another electronic reason for doing that.
Your restoration looks awesome BTW. I hope it is a good receiver and sounds good when fired up.
PostPosted: Jun Tue 20, 2017 1:15 am
I do not spend significant time on cosmetics under the chassis. In the case of the capacitor modules, I re-stuff them with the actual capacitors---mostly to preserve the wiring layout---and, in the case of radios like this one, because that's where the real estate is. This particular set is very cramped---look at the pictures and try to imagine how to get to the various tube pins for trouble-shooting.....:)
PostPosted: Jul Thu 20, 2017 2:44 am
Chapter XX--the speaker
It all begins innocently--the speaker has an open field coil. The good news---it comes apart with nuts and bolts. Here the coil, bell, and armature have been removed revealing the intermediate plate and humbuck coil.
When we see the corrosion, no more thoughts of just "fixing it".
Starting to patch the cone. Note the unique construction, with the cone captured by a ring that is riveted to the basket. I really do not want to take this apart, and so I commit to the RandR of the field coil with the cone in place.
Bobbin on the winder (it is from a roll of solder, but shortened. the spacers are the cores from 3M magic tape---SAVE EVERYTHING!!)
Speaker parts ready to go. The humbuck coil is glued to the intermediate plate to make assembly easier.
"The Kludge"--this fixture holds the intermediate plate centered while the coil and bell are being installed. The drill is to first center the intermediate plate to the VC, then install the field coil and armature / bell. The intermediate plate is centered using a feeler gauge, then the kludge holds it in place. For the last step, we use a feeler gauge from the front.
Done!!---and the VC doesn't rub!
PostPosted: Jul Thu 20, 2017 4:21 am
Ahhhh in depth speaker repair. A labor of love.
PostPosted: Jul Fri 21, 2017 12:34 am
Good job!
PostPosted: Jul Fri 21, 2017 1:50 pm
You guys never cease to amaze me.
PostPosted: Jul Fri 21, 2017 2:05 pm
I have never had a speaker apart where the under plate wasn't fixed in place so never had to worry about that. A neat solution to holding it central in this case Mark, thanks ...
Gary
PostPosted: Jul Sun 23, 2017 1:27 am
Nice work, Mark!
Looks like there are more than just one speaker where removing the field coil causes problems with getting pole pieces in alignment. let alone getting voice coils centered.
This speaker from a Zenith 103 was a real bear, but I fabricated an alignment tool to get it right. I believe this speaker was manufactured by Wright-Decoster of St. Paul Minnesota.
http://www.theradiofox.com/zenith/zenith103/index.html
PostPosted: Jul Sun 23, 2017 1:30 am
The challenge with all the custom fixtures, widgets, etc. is to
--remember what they were for
--build them to be useful for more than one thing
--avoid the temptation to harvest parts from them
etc.
PostPosted: Jul Sun 23, 2017 1:53 am
--or remembering where you put it when you need it again… Arrgh…
PostPosted: Jul Sun 23, 2017 2:45 am
A accurate observation on the side - St. Paul is nothing more than a DUMP in the State of MN these days, so don't go thinking that history of 100 years ago simply continues to apply to this day - far from it. You can give it the name of Dayton's St. Paul Sh%# hole these days.
PostPosted: Jul Sun 23, 2017 9:08 am
"The challenge with all the custom fixtures, widgets, etc. is to
etc."
I adapt chassis mounts Mark but do write on them, with a marker pen, what they were used for and what they do now. Sometimes there are 3 radio makes and models on them. Actually, although I should be able to go back to what they were used for its rare that I do the same chassis again.
Gary
PostPosted: Jul Sun 23, 2017 1:14 pm
That is sad to hear considering it is the state capital…
PostPosted: Jul Sun 23, 2017 1:39 pm
The more you hijack my thread, the more I am motivated to finish the set.....;)
I LIKED St Paul. Among other things, it is Garrison Keilor's home base.
What exactly is the problem?
Post New Topic Post Reply  [ 37 posts ]  Moderator: sofaslug Go to page Previous  1, 2
