It is currently Sep Sun 24, 2017 6:28 pm
Post New Topic Post Reply  [ 1147 posts ]  Go to page Previous  1 ... 54, 55, 56, 57, 58  Next
 Post subject: Re: Roaring 20s Superhets
PostPosted: Mar Sun 26, 2017 3:37 am
Has Rick Ammons Super het web gone away?
See lots of 1920s Superhets at http://www.superhets.info/page5.html
does not work, I had one of the guys at the Charlotte meet ask me about it today.
73, Ron w4ron
Photo tour;
goo.gl/c4UzGS
PostPosted: Mar Sun 26, 2017 5:02 am
I hope not. Rick has lots of good info there. I couldn't connect with Firefox and Chrome redirects and gives me a rollsroyceofreception.com page isn't working. I think it's hosted by godaddy.
PostPosted: Mar Sun 26, 2017 7:26 pm
I talked to Rick and he was not aware that his page was down. He does now and the site should be up in about 48 hours.
David W.
PostPosted: Mar Thu 30, 2017 1:14 am
Here ya go. Perhaps Billy best project.
JL McLaughlin Hallicrafters Superheterodyne
http://www.ebay.com/itm/JL-McLaughlin-H ... SwsW9Y2rRW
PostPosted: Mar Thu 30, 2017 1:15 am
Yowza! Look at all that brass!!! :D
PostPosted: Mar Thu 30, 2017 6:22 am
Wow, WOW ! ! !
that is awesome, and on the cover of a 1924 QST.
What a killer set, I wish I could afford it.
73, Ron w4ron
Photo tour;
goo.gl/c4UzGS
PostPosted: Jul Wed 12, 2017 12:27 pm
Thats one heck of a set!
Consider me a straw in your haystack of success.
PostPosted: Aug Thu 31, 2017 12:32 am
Went to a radio sale today (thank you Art) and came home with a Madison-Moore and a 11 tube Robertson-Davis (R-D) Superhet. The R-D is shown as-found and is missing the meters. I found Duane's info on the transformer test results, but very little else about this company. Anyone know where I might find a schematic, articles, or have more info about this company? It has 11 xfmrs and runs 11 UX199's, all elevated to reduce lead length. Other than the missing meters and no cabinet it doesn't look too bad. All the wiring except antenna and speaker are routed through a Yaxley jones plug.
Thanks, Matt
PostPosted: Aug Thu 31, 2017 12:51 am
Further review of Duane's site shows this set as a Melo-Heald Eleven with lots of info. Thank you Duane.
PostPosted: Aug Thu 31, 2017 4:32 am
Nice score on the Madison-Moore and the Melo-Heald Eleven superhets!
I believe the transformers on your Melo-Heald are an early design with the terminals on top.
My 2 sets have transformers with the terminals on the bottom.
The earlier transformers seem to be rarer than the later transformers.
www.duanesradios.info
PostPosted: Aug Thu 31, 2017 4:54 am
Thanks Duane. I've been reading everything I can find and was going to ask you if it was early or late? Having the terminals on top allowed shorter leads. It seems to match your factory brochure almost exactly except for the glass panels. Is the brochure dated? Also I was obviously wrong in my assumption it ran 199's instead of 01a's.
Matt
PostPosted: Sep Fri 01, 2017 3:43 am
matt's basement wrote:
Having the terminals on top allowed shorter leads. Is the brochure dated?
Hi Matt,
I can't remember if the brochure is dated or not. I don't think it was. I still have it, but I moved a few months ago and I haven't sorted out all my material yet.
The Melo-Heald Eleven transformers with the terminals on the bottom match the style of the Hot Spot 14 transformers, which suggests they are the later design.
As far as the terminals on top allowing shorter leads, that is only the case if the tube sockets are raised on a shelf
or the transformers are mounted under the basepanel (as in Michael Ferdt's Melo-Heald Eleven).
The terminals on tube sockets are at the bottom, and I suspect that's why Melo-Heald started putting the terminals on their transformers at the bottom
(To allow shorter leads between the tube sockets and the transformers).
Duane
PostPosted: Sep Fri 01, 2017 11:25 pm
Thanks again Duane. Your explanation make sense. I will have to keep a lookout for the proper Jewell meters. Went back to the seller's place again today to look for them, but had no luck. I did however come home with another load of old junk I don't need. It's a very sad place. I may be wrong about some of the details but a long time local collector passed away quite some time ago. His widow was apparently overwhelmed by all the stuff so she just left it sit collecting dust. She is elderly and has now moved into assisted living quarters and sold the house with the contents to a young couple trying to make a living flipping houses. I was in the shop area going through stuff and moving mouse poop when I picked up a couple boxes from the floor to put some parts in. Then I realized the boxes were the original shipping containers for AMRAD Detector-amplifier #2634 and AMRAD shortwave tuner #2596.
Matt
PostPosted: Sep Sat 02, 2017 6:30 pm
Good luck on finding the meters for that Melo-Heald. I think your set is nicer than either of mine.
What does the Madison-Moore look like that you found?
PostPosted: Sep Sat 02, 2017 11:22 pm
Cabinet is a floor model standup. Has lots of room for batteries and there is a Yaxley autoswitch mounted on the bottom. The chassis is in good shape, but needs a thorough cleaning. The schematic is attached to the inside lid and looks like it is the original clipped from a magazine article.
I bought several other radios including this little one tube regen homebrew that had this great pair of Pacent 150 MICROVERN dials!
I filled the truck up twice and as of today I'm still married. I will be setting up at the next ARCI and WARCI swapmeets because I am busting at the seams.
Matt
Last edited by matt's basement on Sep Sun 03, 2017 12:10 am, edited 1 time in total.
PostPosted: Sep Sat 02, 2017 11:40 pm
Five page (Melo-Heald Eleven) construction article as referenced by Duane.
Citizen's Radio Call Book. Spring-1927
http://americanradiohistory.com/Citizen ... r-Page.htm
Direct download: http://americanradiohistory.com/Archive ... -March.pdf 22.2MB
Great website Duane... :)
PostPosted: Sep Sun 03, 2017 12:46 am
Matt: Wow, that's a great looking Madison-Moore! I like the Pacent dials also. It looks like you found a nice little honey hole,
Thanks for posting the photos.
Greg: Thanks for the kind words on my site.
PostPosted: Sep Sun 03, 2017 6:04 pm
http://magazineart.org/main.php/v/techn ... 6.jpg.html
PostPosted: Sep Sun 03, 2017 8:30 pm
homebrew wrote:
http://magazineart.org/main.php/v/technical/qst/QST1924-06.jpg.html
Cool, in the basement at the same sale I found a box of QST's dated 1923-1927. Very briefly sorted into a clean box. Some missing, some dups. There are a few early QST's online, http://www.rsp-italy.it/Electronics/Magazines/QST/
PostPosted: Sep Tue 19, 2017 2:03 am
I have had a long dry spell when it comes to adding 1920's vintage superhets to the collection, but the last few months I have picked up a few. Here is my purchase from the fall Kutztown meet. I have identified it as a Tryman 72, the DC version. Uses three 22 tubes and four 01A's. Ad pictures of the period show that it should have tube shields but there is only a 1/8" or so tall ring around the sockets, not much to secure a tube shield in place. Can anyone else share a picture of their Tyrman 72 chassis?
David
Post New Topic Post Reply  [ 1147 posts ]  Moderator: sofaslug Go to page Previous  1 ... 54, 55, 56, 57, 58  Next
Users browsing this forum: Eddy, ekimetsok, h.amberger, Tim Tress and 19 guests
