It is currently Jun Mon 18, 2018 5:13 am
 Post subject: Stuck control shafts
PostPosted: Jan Sun 07, 2018 9:40 pm
DONT Force them ! Frozen up volume control or tone control shafts are common. this is caused by the grease drying up in the bushing. The secret fix is HEAT. First shoot WD40 or similar around where the shaft exits the bushing. Then, take your 33-40 watt solder pencil with CHISEL tip (what you should be using on vintage gear) and put a little solder on it to help the heat transfer, and put it on the bushing for a minute at least. Then turn, usually in the clockwise direction but you can check the control's position in advance by measuring the resistance from one end to the wiper, then you know where it was left last. Almost always, vol controls are left in the low or off position, tone controls you never know.
This method works 90% of the time.
Once loose, keep working it to draw in the new lube. You may have to repeat.
Mark Oppat
Antique Audio
Plymouth, MI
 Post subject: Re: Stuck control shafts
PostPosted: Jan Sun 07, 2018 11:32 pm
Words to the Wise. +1
PostPosted: Jan Mon 08, 2018 4:58 am
Thanks Mark
I always used my big soldering gun to heat them up. I also put the pots so the bushing was up vertically, so the lubricant could flow with gravity & heat.
Your suggestion also works well on T/T with frozen platters, motors, spindles and such.
FrankB
WB7ELC
Member: TCA & Steel Soldiers.
" Break down the wall"
PostPosted: Jan Mon 08, 2018 6:56 am
FrankB wrote:
Thanks Mark
actually with heat, no need to put the control facing up, heat will help draw in the lube. Doesnt hurt though. BTW, you are dead-on about freeing up phono parts, the main one is the "reject cam" that is on an axle that is sometimes riveted to the deck. I have seen them freeze on the axle but still get "driven" around because the axle rivet is loose enough ! Not good of course but amazing they sometimes still work like that !
Mark Oppat
Post New Topic Post Reply  [ 4 posts ]  Moderator: Chuck Schwark
