It is currently Jun Sun 24, 2018 12:13 am
 Post subject: Asbestos substitute
PostPosted: Feb Fri 23, 2018 1:37 pm
Hi guy's, we run into asbestos once in a while, had a Zenith radio that the asbestos fell from the top of cabinet laying on top of the chassis. Found a replacement, I use a silicone baking sheet good up to 450 degrees. It sells in a roll easy to cut, but I found it very hard to glue so I just staple it in place. Find it in the cooking section at your favorite store.
Jim KA8ZXJ
Spring Lake MI 49456
 Post subject: Re: Asbestos substitute
PostPosted: Feb Fri 23, 2018 4:11 pm
I've been thinking of using Kapton. It comes in sheets or rolls of tape.
From an ebay auction:
"Polyimide is an advanced polymer originally developed for the aerospace industry. It has high temperature resistance over 300oC (572oF). At very high temperatures such as 350oC the film may become darker, buckle, but will not burn and will not melt on your work surface. "
PostPosted: Feb Fri 23, 2018 6:10 pm
Ceramic insulation is available in rolls, is inexpensive, and does the same jobs as the original, preventing heat damage or fire prevention.
PostPosted: Feb Sat 24, 2018 1:12 am
Some people use fiberglass cloth.
PostPosted: Feb Sat 24, 2018 2:02 am
+1 for Stephen's ceramic cloth recommendation.... Off eBay I got a sheet delivered for (I think) $9.
Robert
PostPosted: Feb Sat 24, 2018 12:50 pm
Great forum, got some great ideas to check out thanks guy's.
Jim KA8ZXJ
PostPosted: Feb Sun 25, 2018 3:41 am
When I worked with it, they called it "ceramic mat."
PostPosted: Mar Fri 02, 2018 5:54 pm
I've successfully used a silicone kitchen hot pad.
PostPosted: Mar Sun 04, 2018 10:39 pm
That is what I have been using.....................
Jim KA8ZXJ
Post New Topic Post Reply  [ 9 posts ]  Moderator: Chuck Schwark
