It is currently Dec Fri 14, 2018 11:55 pm
 Post subject: When did these start selling for so much?
PostPosted: Mar Sat 03, 2018 3:11 pm
https://www.ebay.com/itm/VINTAGE-HEATHK ... 2413708237
I am used to seeing these unsold at radio meets
Art's Antique Radio Collection - A work in progress
http://www.myantiqueradio.com
 Post subject: Re: When did these start selling for so much?
PostPosted: Mar Sat 03, 2018 4:36 pm
Here's your answer. https://www.ebay.com/sch/i.html?_from=R ... 28&_sop=16
Maybe you should start buying these up and reselling them. I think it's the audio fanatics that are paying the big bucks and not us old radio collectors.
When searching for completed auctions on all capacitor checkers, the Heathkits seem to be way on top. https://www.ebay.com/sch/i.html?_from=R ... 28&_sop=16
Michael Feldt
www.indianaradios.com
PostPosted: Mar Sat 03, 2018 5:51 pm
No one of this forum spending that much on one. Myself included.
PostPosted: Mar Sat 03, 2018 6:22 pm
Wowsa!
$380 bucks! Good grief, time to to scour the Ham flea marts, these did go for $10 not long ago...
Even the manual is bringing $40 :shock:
"Gandhi"
PostPosted: Mar Sat 03, 2018 7:05 pm
Those were always less than $50 at hamfests.
Heck, you're better off with a Sprague Tel-Ohm-Mike or other better cap testers with actual meters to measure the leakage current.
PostPosted: Mar Sat 03, 2018 8:31 pm
I agree with steve. About 4 years ago at a hamfest, I saw a Pyramid CRA-2 at a Hamfest. I had never seen one before.
But since it was only $10.00, I bought it. I didn't really understand the benefit of the meter until I watched this video;
https://www.youtube.com/watch?v=Ycf05jt3_ZY
Now I use it a lot. The leakage current and insulation resistance tests really tell you if a capacitor is good or not.
As for the Heathkit IT-28's, I guess the audiophools want them to test their bumblebee and black beauty caps.
PostPosted: Mar Sun 04, 2018 12:42 am
Chas wrote:
Wowsa!
Exactly what I was thinking. :lol: :lol:
Obviously the testers aren't rare.
You'd have to change a lot of Caps to make that pay off. :shock:
Better off buying $450 worth of needed caps, & saving yourself time in checking for bad caps, why bother anyway? When you finally reach the 450 mark, there will still be plenty of testers left for sale, if you're not tired of changing out caps by then.
If you plugged all 6 test leads into one, you might be able to BS & convince the *bumblebee lovers* that the "Rich Smooth Tube Sound" will soon be going away. :wink:
Lloyd
__________________________________________________________
Advice-It's like Cooking. You have to Taste it First, before you Feed it to Others.
PostPosted: Mar Sun 04, 2018 1:01 am
Hello Guys,
wow that is just crazy those prices I can buy a used Sencore Z-meter and I do need one too since my LC-53 stopped working
Sincerely Rich
PostPosted: Mar Sun 04, 2018 2:13 am
Yes, the Sencore Z-Meters are even better. Even the lesser Sencore CA55 usually goes for reasonable prices.
The Pyramid CRA-2 is a very nice one! I started off with the earlier CRA-1. It makes all the difference IMHO.
Solar and even lafayette have advanced models with milliammeters.
I went off and made my own design which is now my favorite next to the LC-101 Z-Meter.
PostPosted: Mar Mon 05, 2018 12:10 am
Wow. Audiofools.
PostPosted: Mar Mon 05, 2018 1:46 am
Where is the schematic?
PostPosted: Mar Mon 05, 2018 2:11 am
PostPosted: Mar Mon 05, 2018 3:27 am
Great work Steve. It will take me a bit to digest this. The multi-transformer approach is really a great idea. What is the max voltage you have available? Why did you use a 15v winding for the 1629 (with the dropping resistor)? Transformer you had or a different reason?
PostPosted: Mar Mon 05, 2018 3:36 am
CrumblingWires wrote:
Wowsa!
Lloyd
[/quote]
+1
Brian
PostPosted: Mar Mon 05, 2018 1:58 pm
At first I thought that was a layout to a Rube Goldberg machine but I guess that what you get when you draw out schematics free hand. Nice engineering there, Steve.
Michael Feldt
PostPosted: Mar Mon 05, 2018 3:01 pm
Thanks Michael, I should re-write the schematic, but its what I put together back when I built it.
I had to redo several things along the way to get it the way I wanted it.
The leakage voltage maxes out about 700 or so. Not many reasons to go that high really.
I can't remember where I found that second transformer for the bridge circuit, but most parts came from an old Conar cap tester I tore apart. I didn't like that most cap testers, the negative lead is not at ground potential, so I did some rearranging to make it so. The 15 volt winding is not only used for the 1629 heater, but also supplies the bridge. The original was about 30-40 VAC. It turned out 15 was plenty to work with.
The whole project was doing what I could with what I had available to me. In the end it was a very satisfying project :D
PostPosted: Mar Tue 06, 2018 3:12 am
hmmmm perhaps this is the reason?
https://youtu.be/lLQThhf3Brc
FF to 6:08.
IT-11 and IT-28 both selling for quite a bit more than I personally think they should.
Steve
PostPosted: Mar Wed 07, 2018 11:02 pm
I think its all about the magic eye.
- http://www.nixies.us/
PostPosted: Mar Wed 21, 2018 6:11 pm
Apparently, the Heathkits aren't the only ones selling for crazy prices these days.
https://www.ebay.com/itm/Vintage-NRI-11 ... true&rt=nc
PostPosted: Mar Wed 21, 2018 10:13 pm
Those kit built training course testers are the lowest quality of the lot.
:shock:
Post New Topic Post Reply  [ 24 posts ]  Moderator: Lou deGonzague Go to page 1, 2  Next
Users browsing this forum: Zenith Royal and 6 guests
cron
