It is currently Sep Wed 19, 2018 2:03 am
Post New Topic Post Reply  [ 678 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34  Next
 Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic)
PostPosted: Feb Mon 20, 2017 8:22 am
john8750 wrote:
How could you wait?
I was screwing around with trying to understand the 5 band resistor code. What a PITA. Then it was dinner time.
Very exciting to just get the proper voltages. Will work on it tomorrow.
I called you, but you must have been out katt in around.
I be here now
PostPosted: Feb Mon 20, 2017 8:36 am
john8750 wrote:
But I had to make a new chassy.
What is that? .... :mrgreen:
PostPosted: Feb Mon 20, 2017 7:50 pm
A chassy is a chassis before it has anything mounted on it :wink:
Gonna try to pollute the air today. I wonder about L3. The choke Mouser sent me looks nothing like the one others used.
Had to deal with my women last night, forgot to call back :lol:
John Smith, over and out.
PostPosted: Feb Tue 21, 2017 2:11 am
I'm on the air :!:
Hooked up a four foot antenna, and an ipod. Found the spot real easy. Seems the carrier is wide enough. The voice quality is not hi-fi, but pretty good. The trimmer cap seems to make no difference. Might be better with a 10' antenna. The radio was 12 feet from the transmitter with no problem. Tomorrow I will try to receive inside the house. Transmitter is in my shop, about 50' away. A fun project and easy to build.
Thanks to the designer and Deadshort for the kit. Also thanks to the Man who put this neat kit together for us. Seems that I am years late, but very happy with the results. Will post photos and more info 8) 8)
PostPosted: Feb Thu 23, 2017 12:49 am
Still out in my shop I connected a 10' wire antenna. Still, the tuning cap has no effect. I received the station out in my car, about 45' away, very strong. But inside the house, about 60' away, very week. My house is a prefab with aluminum siding. So placing the transmitter inside the house should work better.
I am waiting for a better volume pot to arrive. The mini pot works fine, but not long enough to install the knob. So I need to clean and restore the BTL cabinet. Also need to manufacture a way to mount the tuning knob back on the box. It will be there for looks only.
This is a great project. Very simple and works very well. Thanks again Men. :!:
PostPosted: Feb Fri 24, 2017 10:08 pm
If the tuning cap has no effect either it's defective, badly off spec, or the coil inductance is out of spec... Even if correct value, inductors meant for power supply useage won't resonate at RF frequencies...
PostPosted: Feb Sat 25, 2017 12:15 am
Thanks. Are you saying that my L3 is not the correct type? I can change it. Or L2? I will check the trimmer values on an LCR meter.
PostPosted: Feb Sat 25, 2017 12:48 am
If coil is causing tuning problem it would be L2...
PostPosted: Feb Sat 25, 2017 12:57 am
Thanks again. I will check it. It is the correct type. I did not check it for the correct value.
PostPosted: Feb Sat 25, 2017 2:23 am
I checked L2 at 1.01uh. So that is perfect. But VC1 stays at 54pf all the way through its travel. Should be 365pf.
Let me get a replacement. Other than that, the transmitter works well.
PostPosted: Feb Sat 25, 2017 4:12 am
Do you mean 1.01mh?? 1.01uh is far too small value...
PostPosted: Feb Sat 25, 2017 4:35 am
Oh yes, it is the same as L1, 1mh.
I can get VC1 as a rotary tuning cap. Is that OK to use?
http://www.ebay.com/itm/132032487083?_t ... EBIDX%3AIT
PostPosted: Feb Sat 25, 2017 5:19 am
John, as a test you can try any old AA5 or the like var cap.
When you tune the sweet spot, it will be like falling in love... again. :lol:
More "L" and less "C" seems to be the rule. They say why waste transmitter power through the air (variable).
PostPosted: Feb Sat 25, 2017 7:41 am
John:
Are you sure you are connecting that variable cap at the correct places?
The blades rotate... in the stator.
You should measure between the movable plates and the fixed plates ot housing.
PostPosted: Feb Sat 25, 2017 9:52 pm
Thanks guys. I have the trimmer type. It does not have discs. It is mounted correctly, and not shorted.
I will order the tuning cap and install it. I don't have an old AA5 for parts.
PostPosted: Apr Mon 10, 2017 12:52 am
My DVD Player/Recorder on my Dell 8400 PC quit working
Sooooo Went looking through my Computer Parts.
Found a Box labeled 2 Good HD for 8400 PC
When opened I learned it contained the COMPLETE kit from Bill Hamre for the 12AV6/12CS6 Transmitter I purchased years ago and lost.
Like Christmas
Bob T
PostPosted: Apr Mon 10, 2017 3:26 am
I repaired my transmitter. The antenna trimmer was glued to a piece of wood, and then to the chassis. But some glue was holding the trimmer plate closed. So I fixed it and now it works better. A real nice little kit. Thanks again. I'm gonna use it to re-broadcast AM1260 from my tablet and receive it on AM1000 with the 1946 RCA I just rebuilt.
PostPosted: Apr Mon 10, 2017 8:51 am
Let us know how that works John.
PostPosted: Apr Mon 10, 2017 5:47 pm
I will Peter. I don't see a problem. If anyone would like a tube AM broadcaster, build this set. A very simple and rewarding project.
PostPosted: Dec Sat 30, 2017 9:27 pm
I think that it's well overdue to open up an old thread. Given that the Electronic Goldmine G12951 (Epec YS57H-110FA equivalent) transformers just don't seem to be available anymore for the 12AV6-12CS6 AM transmitter kit, why can't one just substitute in a simple 12VAC 2A power transformer to begin with? Basically, all one then really needs is a full wave bridge connected to the line, and that should deliver something like 170VAC RMS for the B+. Of course, we would also need a 5VDC power source for the can oscillator, but I would imagine something can be conjured up (with a little ingenuity) by tapping the 12VAC secondary along perhaps with the inclusion of a simple 5VDC regulator. This is just something from the top of my head, but it's just a thought. Any other suggestions?
