It is currently Feb Sun 17, 2019 3:25 am
Post New Topic Post Reply  [ 67 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: TV transmitter ideas
PostPosted: Sep Wed 12, 2018 8:28 pm
Hello all,
I have been thinking about building a simple TV transmitter for my vintage TVs. Basically what I'm trying to build is just a small amplifier that can take the RF output from a DTV converter and transmit it over the air. Some time ago I experimented with simply adding a wire antenna to a piece of coax with success. With a bit of amplification it should be fairly easy to build something that sends a signal around the house. I imagine you could use something like an antenna or cable amplifier like used in large buildings with many TVs but I would enjoy making something homebrew. I have a couple of VHF RF transistors at my disposal, though of course it should be kept legal.
Anyone have any ideas or schematics?
-Carlos
 Post subject: Re: TV transmitter ideas
PostPosted: Sep Wed 12, 2018 8:49 pm
Why? Just buy a modulator that can be programmed for VHF or UHF or both.
PostPosted: Sep Thu 13, 2018 12:59 am
That would be cool if you want to do it the hard way.
The easy way is to get one of those Blonder Tongue agile modulators for $30-$50 on eBay... one that has DIP switches to change the channel. They were intended for closed circuit operation but they work great as low power transmitters if you stick a wire in the RF output jack.
I flermmed the plootash just like you asked.
PostPosted: Sep Thu 13, 2018 12:08 pm
The radiation limits in the US for unlicensed operation in the TV bands are pretty tight. I don't know about Mexico.
PostPosted: Sep Thu 13, 2018 1:55 pm
I don't know if it was FCC rules or just that the tech was cheap and available, but it seems that all the consumer video transmitters I've seen were in the 900mhz band.
PostPosted: Sep Thu 13, 2018 2:17 pm
What's the frequency of operation you are looking at and what RF transistors you've got? I'll cook up a simple linear amplifier schematic for you after you tell me the frequency of operation. I ain't sure of the legality of it but power output can be kept quite low to cover a short distance like 100 meters. 20 mW output should be sufficient.
PostPosted: Sep Thu 13, 2018 2:22 pm
Try this simple linear amplifier. RFC is 1 uH or 50T of thin wire on a 100k resistor. The driver transistor is 2n2369 and final one is 2n3866. It's suitable for 100 - 200 MHz
PostPosted: Sep Thu 13, 2018 2:24 pm
EDIT: Based on the title of this thread, I was going to suggest a separate oscillator circuit with video only input until I read your post more carefully and realized that a linear amplifier would be sufficient.
PostPosted: Sep Thu 13, 2018 2:28 pm
Years back I fed a microwave channel, converted to Ch 5 into a eight tube Winegard distribution amp. Driving a VHF antenna, neighbors on my side of street(line of sight) could easily receive it four houses down.
PostPosted: Sep Thu 13, 2018 2:37 pm
https://ibb.co/iruEVU
Simple linear amplifier using one 2n5109 / 2n3866.
Adjust input and output trimmer capacitors for best range. Make sure you get a genuine transistor from mouser electronics, etc. Avoid Ebay. I received fake 2n3866 transistors with only 4 dB gain in the FM band. 2n5109 will give the best gain. It can't get any simpler than this.
PostPosted: Sep Thu 13, 2018 5:06 pm
I built a low power TV transmitter (video & mono audio) about 15 years ago. I bought it as a pc board
and board mounted parts only kit. Got it from North Country Radio < http://www.northcountryradio.com/ >
but I see they no longer carry it. Works great and tunes to any channel from 2 - 6. I've used it with DVD, VCR,
and video camera. Produces good video and audio and with a short antenna will cover most of my house. No
special parts in it. I'll look for the schematic. The small blue board is an added voltage regulator.
Al
Found the info, here is the schematic and board layout. I'll do a better scan when I have time.
PostPosted: Sep Thu 13, 2018 10:21 pm
Thanks a lot for the info guys, I want to build something for the sake of having a project and to save some money since I figure I can build something out of scrap.
Perfect! I have a 2n3866 right here. :D I also have a 2N4427 both ordered from mouser. I hope these dont get discontinued soon since they seem good for a lot of purposes. The frequency I'll be using it on will be either channel 3 or 4. Seems that's around the 65mhz range according to google. Is this the frequency you designed this for? Since you used a resistor for the former, did you use a 1/4 watt or 1/2 watt resistor? Approximately what gauge wire did you use?
Also hope you can find that schematic, Al!
-Carlos
PostPosted: Sep Thu 13, 2018 11:20 pm
65 MHz? Use the 2n3866! Let me know the range you get. I use 70T of 37 AWG wire on a 100k - 1M resistor as my RFC in VHF circuits. You can use a ready-made moulded choke if you have one.
PostPosted: Sep Thu 13, 2018 11:24 pm
Thanks!
is that a 1/4 quarter watt or 1/2 watt size resistor, just so I know the size for the former. If I use a ready made choke, what value would that be? I imagine the resistor is still necessary right? Sorry if that's a dumb question. lol
-Carlos
PostPosted: Sep Thu 13, 2018 11:37 pm
Nope the resistor is not necessary. Winding 70T on 1/2 W resistor will give you more inductance. On 1/4 w resistor it gives me 1.5 uH. Use a 10uH choke. Got one in your junkbox?
PostPosted: Sep Thu 13, 2018 11:40 pm
There should be one around here somewhere. Let me check, if not I'll use the resistor. I think most of what I have are classified as inductors, they look like this. https://tmgeletronica.com.br/Eshop.Admi ... uctors.jpg
I'm not sure if that would work. Besides that most of what I have is on ferrite.
If I go with the resistor method do I go with the 1.5uh or do I need the higher inductance from the 1/2 watt resistor?
EDIT: Would it be a good idea to use an adjustable coil for this in order to obtain maximum output? I have lots of 8mm formers with a slug in the center like those found in the output stages of CB radios. What would be a good amount of turns and wire gauge to use on this for the purpose should this be a good alternative?
-Carlos
PostPosted: Sep Fri 14, 2018 1:18 am
Use a big inductor as frequency is low. Inductive reactance of 1.5 uH is only 600 ohm or so at 65 MHz. Find a ready-made moulded inductance of 10 uH or more and you would be fine. No need to use a variable inductor unless the collector is tuned to 65 MHz. Using a RFC will give broadband characteristic. The idea is to have enough inductance so it offere high resistance to 65 MHz RF while letting DC to pass through. 10 uH or more is okay.
Use this at the output and adjust trimmer capacitors for highest voltage reading
https://ibb.co/cmPmvU
Then connect a 1/4 wave wire antenna and ur all set
PostPosted: Sep Fri 14, 2018 2:53 am
Thanks. Closest I could find at the moment is 20uH. I guess in any case I could take off some turns.
-Carlos
PostPosted: Sep Fri 14, 2018 4:58 am
20 uH is good! I hope the drive level is enough to give usable gain from the 2n3866. You should get a 50 meters range.
PostPosted: Sep Fri 14, 2018 5:42 am
Many years ago I set up radiation type TV signal boosters for stores
the firm operated. The amplifier was a 30dB booster made by Delco
for networks of 75 ohm splitters.
The signal feeding the amp was about -6 dBj.
The output fed a VHF Yagi type antenna placed in the false ceiling
of the store.
The store display was interesting, at the back of the store, wall to wall
TV sets three high on shelves made for the purpose. I recall we were
hawking Westinghouse portable BW sets 1966ish.
If you walked by not paying attention, and the image on the TVs
shifted right or left, it was like sensing a train pulling out. You might
lose your balance. I think that was exactly what our store designer
wanted as an effect.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
