It is currently Feb Wed 20, 2019 2:17 pm
Post New Topic Post Reply  [ 48 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: One-Dollar-Tube Guitar Amp
PostPosted: May Fri 13, 2016 6:38 am
Hmmm... I found a bit more info concerning the compensation cap [what I was calling the bypass cap]. From what I've gathered, you first need to measure the gain and phase shift of the open loop gain stage. If it crosses 180° then you pick a cap that will shift it to under 180°. All the equations shown make it look quite complicated, but I've found that this kind of thing is actually pretty simple to setup in Excel then use goal seek to work it backwards.
Use the COMPLEX function to convert reactive components to a complex value, then you can use the same basic equations that you would use for pure resistors. You need to use the IMSUM, IMSUB, IMPRODUCT, and IMDIVIDE functions instead of +,-,*, and / in the formulas. In the end, use the IMABS function to get the amplitude from the complex number and the IMARGUMENT function to get the phase angle.
PostPosted: Jun Thu 02, 2016 10:13 pm
I have yet to pick up a soldering iron, life really gets in the way sometimes. I did manage to fully geek-out on the circuit analysis. What started all this was a concern that the 6N2P tubes would have too much gain compared to the 12AX7 tubes that the Fender circuit uses. Both tubes have the same amplification factor of 100 but the 6N2P has a lower internal plate resistance so the actual gain will be higher, especially for the first pre-amp tube that feeds the tone stack.
In order to check this, I had to build a Thevenin equivalent circuit for the tone stack which took me the better part of a week. The rest of the math was pretty straight forward and includes the low-frequency roll-off from the cathode bypass capacitors and the high-frequency roll-off from the Miller capacitance of the tone stack recovery tube.
The following graph shows the pre-amp gain from simply swapping the various tubes.
The 6N2P is basically the same as the 12AX7 except it doesn't roll off as fast on the high end due to it's lower capacitance. The 12BZ7 and 5751 are also very similar but the 12BZ7 has higher capacitance and rolls off sooner. The 6AQ8, 12AY7 and 12AT7 are all grouped at the bottom, with the 12AT7 the lowest of the bunch.
Things change pretty drastically if you re-bias the tubes by changing cathode resistors.
The 12AX7 and 12AY7 stay pretty much the same. The 12BZ7 gain skyrockets. The 6N2P also jumps considerably above the 12AX7. The 6AQ8 is about where the 5751 started. The 5751 is right at the heels of the 12AX7, and the 12AT7 jumps from the bottom to almost overlapping the 12AX7.
PostPosted: Jul Tue 12, 2016 9:24 pm
I finished drawing the schematic over a month ago and have collected up most of the parts. Unfortunately, since then, I have filed for divorce and am now a single father of three. I was planning to post the schematic after I had a chance to experiment with it and make improvements, but at this point I have no idea when/if that is going to happen. So, here is the unfinished schematic.
http://www.gofastforless.com/junk/po_reverb_schem_2016_06_10.gif
I started with a Fender Pro Reverb schematic and removed the Tremolo and Normal channel, realizing after the fact that it now looks more like a Princeton Reverb and it would have been a whole lot less work starting with the Princeton. The preamp, reverb, and phase inverter are basically direct copies of Fender circuits. The stuff to the right of the phase inverter is mostly ideas I've had floating around in my head and decided to try out here. It may be the bee's knees or just a recipe for smoke. The plan was to "breadboard" all the experimental stuff in the old Bogen chassis then transfer anything that worked into the new amp chassis and add the tried and true Fender preamp and reverb. Hopefully, I will be able to get back to this project one day.
PostPosted: Jan Sat 20, 2018 7:02 am
I'm happy to report that the dust has settled and I'm able to pick this up again. The plan has changed a bit. Rather than converting the speaker cab into a "Blackface" combo, I'll convert the Bogen to a "Brownface" head that I can use with the cab.
I've never been a fan of Tremolo but after hearing the Brownface "harmonic tremolo" in some youtube videos I just had to make one. In a nut shell, it's like a modulated tone control instead of a modulated volume control like most tremolos. The circuit looks insanely complicated at first, using two and a half 12AX7 tubes, but when you break it down it's an ingenious collection of simple circuits. A cathode follower buffer on an oscillator, driving a cathodyne phase inverter which modulates the bias on two common cathode gain stages. The preamp signal is split and run through two different tone shaping circuits each going to one of the gain stages. The outputs of the gain stages are mixed then sent on to the phase inverter for the power tubes. Since the two gain stages are modulated opposite each other, the volume stays fairly constant but the tone moves around as well as having some interesting phasing due to slightly different phase shifts of the tone shaping circuits. There isn't anything that sounds quite like it. Although there were some Vox amps with similar tremolo circuits.
If I can scare up the unique tapped tone pot then I'll copy the Brownface preamp and tone stack. The power supply and output will be tweaked to work with the Bogen transformers and a pair of 6GT5 power tubes.
I've just about finished gutting the Bogen chassis. It needs some straightening because it was dropped pretty hard at some point. It'll get a thorough washing but all the surface rust and flaking paint will remain [for now]. I think the only parts I need to buy are the odd ball pots.
PostPosted: Feb Sun 25, 2018 5:34 am
The chassis is completely stripped now and I was able to find most of the odd-ball pots. The next step is some mechanical work, straightening, drilling and machining, but it's been below freezing in the garage so I haven't been very motivated.
I finished the preliminary schematic. http://www.gofastforless.com/junk/po_6g5-b_2018_02_23.gif Starting with a "Brownface" Pro Amp, I removed the Normal channel then changed the power supply and output to use the Bogen transformers and 6GT5 tubes. Also changed to a cathode bias on the power tubes and added an adjustable screen supply.
The 6N2P works in place of the 12AX7 everywhere but the cathode follower in the tremolo circuit (heater-cathode rating is exceeded). The 6DT8 should work fine there without any changes to the circuit. The other half of the 6DT8 is used for the adjustable screen supply.
The place that had the special tapped tone pot had all the other odd-ball pots except the 10meg reverse audio used for the intensity control. I changed the values of the caps and resistors in the intensity circuit to have a nearly identical slope and frequency response with a 3meg reverse audio pot.
PostPosted: Mar Fri 02, 2018 11:50 pm
I was curious what the difference is between the Blackface and Brownface tone stacks. A web search turned up plenty of opinions about how different and unique the Brownface tone stack sounds but there weren't any hard numbers to really quantify the difference. I spent a day building a function in Excel to model the Brownface tone stack (having already done one for the Blackface tone stack) and the results are kind of surprising.
The bass controls are nearly identical between the two so I didn't bother charting different settings. All traces on the chart were done with the bass set to 60%.
The treble control on the Brownface circuit from 38-100% is basically the same as the Blackface treble control from 0-100%. Turning the Brownface treble below 38% provides a treble cut that you don't get with a Blackface circuit.
Had I known this before, I probably wouldn't have wasted time and money hunting down the special tapped treble pot for the Brownface circuit. I can't remember ever turning down a treble control all the way and thinking to myself, "I wish this treble control went down further." Oh well, I've got the pot now so I might as well use it.
PostPosted: Mar Sat 03, 2018 5:35 am
Alright, the Brownface tone stack was a bit underwhelming but the real magic to this amp is the harmonic tremolo. The signal passes through the tone shaping mixer circuit whether you are using the tremolo or not (unless plugged into the Normal channel). The frequency response of the mixer is far from flat. The signal coming from the preamp is split and run through two different bandpass filters. Each signal is amplified then they are mixed together. The following chart shows what the output of the mixer would look like if fed a flat signal.
The frequency response is similar to the tone stack with a prominent mid-scoop. To get a flat frequency response out of the mixer the tone stack would have to cut the highs AND lows going into the mixer. The Brownface tone stack can cut the highs but not the lows. With the bass control turned all the way down, the low frequency response stays pretty much even with the mids. The net result is that the lows are always boosted by the mixer. I imagine that this is why the Brownface amps are said to have a "darker" sound than the Blackface amps. A Blackface amp also won't cut lows but with the bass and treble turned all the way down, you feed a fairly flat frequency response into the power stage.
When the tremolo is engaged the two peaks rise and fall opposite each other. The effect is like turning the treble knob up and the bass knob down at the same time, then treble down bass up, back and forth, back and forth. Your ear perceives it as kind of a Doppler effect, similar to a Leslie rotating speaker. Obviously, it's not the same thing as a Leslie but there's really nothing else the harmonic tremolo can relate to.
PostPosted: Mar Fri 16, 2018 8:15 pm
Just stumbled on this today. Can't wait to hear how it turns out! I love using oddball tubes to make cool stuff. Got an amp at home that uses two 6J5 tubes in PP for a power amp. That guy sizzles!
