It is currently Jan Wed 16, 2019 6:23 am
Post New Topic Post Reply  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Need pass transistor test jig
PostPosted: Dec Fri 15, 2017 7:15 pm
They are external. Otherwise you use THE D cells placed inside the tester.
A complete manual is here :
https://elektrotanya.com/heathkit_im-30 ... nload.html
I just might order a newly printed manual, from Manualman. That is so much nicer
than looking at a computer screen
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Fri 15, 2017 7:58 pm
radiotechnician wrote:
They are external.
That link only gave me the schematic.
If I acquire or borrow a IM30 and the also have to build, buy, or find an external power supply to test the 2N5886's to 40v at 10 or 15 amps them it would be cheaper for me to just build a power supply and throw the transistors in it and leave it on under load for some period of time as the results would be the same.
Thank you.
PostPosted: Dec Sat 16, 2017 1:47 am
Electrotanya is a weird site to get anything from at best of times. However..
I got this yesterday.
The IM30 is a static transistor test bridge that uses techniques in use 50 years
ago.
When I use mine, I connect it to a three output Heath power supply.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Tue 30, 2018 5:23 pm
Which 3 output Heath supply? At what voltage and current are they running? I can understand that 2 of those voltages and currents are reasonable and obtainable but one supply would have to be pretty high current (10 amps or more) and higher voltage (40v in my case) to be able to simulate the conditions in my TS940.
