It is currently Jan Sat 19, 2019 7:16 am
 Post subject: Finding IF and tuned LC circuit frequencies
PostPosted: Jan Thu 04, 2018 5:14 am
I built this simple circuit some time ago and still find it useful. You use a signal generator and meter to test the resonant frequency of a transformer or tank. I have used it to figure out IF cans from my junk box. I built it into a box and used a 200 ua meter which works well with my signal generator. The article said you could use a VTVM with it also. When you hit the resonant frequency you get a nice peak on the meter. Given an known value for C or L you could calculate the other components value. I have a frequency meter monitor my signal generator so my readings are pretty accurate. Cheap and easy to build.
Rick
AB5ON
Forest Gumping through life
 Post subject: Re: Finding IF and tuned LC circuit frequencies
PostPosted: Jan Thu 04, 2018 5:54 am
I wonder why they included the RFC?
Pete
PostPosted: Jan Thu 04, 2018 3:32 pm
Isn't that pretty much a circuit for an RF probe as used on many VTVM's?
PostPosted: Jan Thu 04, 2018 5:33 pm
I built this one to test IF cans, the frequency is always a bit low, but it get's you in the ball park. Just hook it up to a frequency counter.
