It is currently Feb Sat 23, 2019 6:27 am
 Post subject: Boost Transformer in Japan
PostPosted: Jan Sat 06, 2018 7:38 pm
I need to put together a few boosting transformers to go from 100V to 115V or thereabouts supplying US spec vintage tube gear in Japan. I would like a 20Amp transformer, but what I have found is one pricey option, one cheap, both at lower current ratings.
First question: The Hammond listed here:
https://www.mouser.com/ProductDetail/Ha ... %2Fw%3D%3D
It has an 8A rating, and a 100VA rating as listed by Mouser and the Hammond spec sheet. I am confused and forgive a stupid question, but shouldn’t that be more like 1000VA?
Do you think I should look for something more like a 14V secondary for my application?
The other option, which is cheap is this:
http://www.surpluscenter.com/Brands/Tod ... 5-1169.axd
A “15V voltage booster.” I found that posted by a user on this forum somewhere when I was researching the topic. Looks like it could be repackaged into a grounded box with a fuse, etc., easily. Claimed rating is 6.4A, so it might not be robust enough to handle my 32V2 transmitter, at 5A, probably my heaviest load.
One other point, the line frequency in my part of Japan is 50Hz, but I believe this isn’t of major consequence in my situation. Tell me if I am wrong.
Your opinions and expertise would be much appreciated.
:D
 Post subject: Re: Boost Transformer in Japan
PostPosted: Jan Sat 06, 2018 7:42 pm
Line frequency is critical to transformer health!
Any power transformer rated for 60 cycles will overheat significantly if operated from a lower frequency to the point of burning up in some cases. You may need to operate at a lower voltage so it doesn't get too hot and melt down. The transformer in your equipment will be at risk unless it's rated for 50Hz if you are planning to run it at rated line voltage.
If you are planning to use a boost transformer on 50Hz, it MUST be a 50Hz transformer.
PostPosted: Jan Sat 06, 2018 7:48 pm
12.6 volts at 8 amps is in fact 100.8 VA
The voltage ratio is 115 / 12.6 = 9.1. If wired to a 100-volt line--in a boost configuration-- you'll get 100 + 9.1 = 109.1
-Mark http://pixellany.com
PostPosted: Jan Sat 06, 2018 10:32 pm
A little more expensive, but there's also these transformers with 100V input and 115/120V output.
https://www.mouser.com/Power/Transforme ... =Pricing|0
PostPosted: Jan Sun 07, 2018 12:18 am
Does not Japan still have both 50Hz and 60Hz power, depending on the region?
And are not transformers to be had in Japan? US sourced iron will be costly to ship.
If you are trying to run a 60Hz transformer powered radio off a 50Hz line, 100V might be pretty OK, if the radio works at the lower voltage.
Ted
PostPosted: Jan Sun 07, 2018 1:01 am
Japan has both 50Hz and 60Hz areas. Naturally, appliances here are designed to run on either.
Simple tube radios (AA5s, S38, etc), without VR, run fine on 100VAC. They take longer to warm up, but they work fine. People here have told me they're still using the original tubes in their vintage US-made 1950s and 60s receivers. Again, simple designs.
Step-up transformers are available here. The cheaper ones are auto-transformers. Here's a link to Amazon Japan:
https://www.amazon.co.jp/
You can also search for them on the internet using this term:
昇圧トランス 120v
Pronounced 'shiyoo atsu toransu'.
Rob
PostPosted: Jan Sun 07, 2018 6:10 am
Thanks, Dennis, I will change my requirements to include 50Hz in the spec. for the boost transformer. Most of the old ham gear I have is claimed by the manufacturer to operate at 50/60Hz.
PostPosted: Jan Sun 07, 2018 6:12 am
Thanks, Mark, I see that's a little low. Will have to keep looking.
PostPosted: Jan Sun 07, 2018 6:32 am
Thank you! This series does what I need in voltage (100 to 115 step up) and have a 50Hz rating. But since these are step up and not used as a boost autotransformer, I believe the secondary current rating is too low unless I got the massive 22lbs unit. I am not clear on that. Please set me straight. (My heaviest single load draws 5A, but I would like to add a receiver or two.) I put in a query to Antek torroidal in NJ to see how much they would charge to build one and how much it would weigh.
PostPosted: Jan Sun 07, 2018 6:39 am
Yes, Ted, Japan is splitsville on power frequency. I live in Tokyo where it is 100V at 50Hz. I am in the US right now briefly for the holidays so I am taking the opportunity to try to figure this out and maybe take something back. My Japanese is not great at all so rooting around Akihabara with a mission is not simple, especially when you have to ask for a technical spec. :oops: And worse if you aren't sure what will work.
Ted
PostPosted: Jan Sun 07, 2018 6:54 am
Thanks, Rob. Imagine that I am like a vintage radio guy in the US, I want to run my vintage gear no higher than about 115V. However I also have modern US spec electronics. I see that some of the transformers shown in the Amazon link you provided have 110 and maybe 120V secondaries (not sure what the "~" in "110~120" means.) So I will look into these with the help of a native speaker.
Step-up transformers are available here. The cheaper ones are auto-transformers. Here's a link to a page from Amazon Japan:
https://www.amazon.co.jp/s/?ie=UTF8&keywords=昇圧トランス+120v&tag=googhydr-22&index=aps&jp-ad-ap=0&hvadid=217403914017&hvpos=1t1&hvnetw=g&hvrand=7334434989279252521&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1009461&hvtargid=kwd-51998620351&ref=pd_sl_7gmkyus1zu_e
You can search for them on the internet using this term:
昇圧トランス 120v
Rob
PostPosted: Jan Sun 07, 2018 10:03 am
'110~120' means the actual output voltage will vary with the load you put on the transformer.
These are, btw, autotransformers, so there is no isolation between input and output.
They are a fairly common item here. Large electrical appliance stores, Yodobashi Camera, Bikku Camera, etc
usually have them in stock. You don't have to go to Akihabara. As you must have noticed, they're not
particularly cheap ($100~$150). But they are well made (traditional Japanese quality, not imported from China)
and you can turn them around to run any 100VAC Japanese stuff you buy here in the States.
As you know, Tokyo power is 50Hz. If any of your equipment must run on 60Hz, it's not going to
work here.
Rob
PostPosted: Jan Sun 07, 2018 6:47 pm
Let me ask you this, then, if I desire 115V, you are saying there is no way to acheive that reliably with an autotransformer boost configuration? Because I do own 2 Variacs, but I'd rather not use those in a permanent installation.
work here.
Rob
PostPosted: Jan Sun 07, 2018 8:18 pm
I have built Bucking transformers for my tube Ham radio. But I went with this for my work bench. The Variac came from my job. It was one third of a 0 - 208 three phase power station. One of the units failed, so I got the other two. I run my whole bench on this. It has input and output circuit breakers, Voltmeter, Ampmeter, RFI filtering on the input and output, and last a run time meter. Put it in because I had one.
PostPosted: Jan Sun 07, 2018 8:43 pm
I have some large 100/120 transformers.
They were made in Japan, and accompanied some very special
lab apparatus, made for the pulp and paper industry.
So a source may be sites that sell things specially marketed
in that industry.
On such site I found my Induktor, A Swedish made electrical
instrument that appeared in paper maker motor shops.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Sun 07, 2018 9:39 pm
The runtime meter is the pièce de résistance! I may end up shipping over my variacs. Have to keep that big knob behind a security cover.
PostPosted: Jan Mon 08, 2018 1:10 am
If you must have a consistent 115VAC, then I think you'll need to bring one of your Variacs.
Homes and apartments in Japan are, from an American perspective. electrically underpowered. I
once lived in a rather nice Tokyo apartment that was limited to just 3KW! That's not unusual.
As you switch your toaster, washing machine, space heater, etc on and off, your voltage will change.
(And btw, don't assume just because your AC wall socket has three prongs it has a functioning
ground. Japan used a two wire system until fairly recently. Sometimes the ground lug is left
unconnected because there's nothing to attach it to).
Have you lived here before? Homes and apartments cannot be described as spacious. No garages
or basements to serve as work rooms or storage. There's a reason Japanese manufacturers are
world leaders in miniaturization.
EDIT: my wife tells me that apartment was originally fused to just 24A/100VAC. We paid extra to have it raised to 30A.
Rob
PostPosted: Jan Mon 08, 2018 8:20 pm
One option if you need steady 115Vac is to get one of those voltage regulating transformers provided one is made for 50Hz and can handle the load of your transmitter.
PostPosted: Jan Tue 09, 2018 9:39 am
Here's what you need.
Put it on the patio, and hope the neighbours don't complain. :)
PostPosted: Jan Tue 09, 2018 2:01 pm
Sky, I didn't notice that you wrote you live in Japan. So you're familiar with both the space and
electric power limitations.
If you don't find what you want in the States, just remember you can get it here.
Rob
