It is currently Feb Thu 21, 2019 9:27 am
 Post subject: I need a data sheet
PostPosted: Jan Wed 10, 2018 7:59 am
RF-Wide-Band-Amplifier-30dB-High-Gain-Low-Noise-LNA-Amplifier-Module-0-1-2000MHz
I saw one of these on E-bay for $6 and thought I might have a use for something like this.
Most usually the supplier will remove the ID markings on these devices so you will have a hard time copying them. I was lucky enough to find one with the marking N02. This amplifier looks like a 1.4amp round bridge rectifier. Same circular 5/16" shape with 4 flat pins at 90* to each other. A Google search turned up nothing for me. That number N02 brought up a larger square chip with a bunch of pins designed for something totally different. Hopefully one of you know of a link or has a semi conductor book with this device listed. I would like to know the operating voltage for sure and anything else would be a bonus. Thank you for your time. michael
 Post subject: Re: I need a data sheet
PostPosted: Jan Wed 10, 2018 1:35 pm
Does it look like this?
https://www.rfparts.com/rftransistors/t ... rf901.html
Motorola made a series of high frequency devices in this package style.
Not an N02 but likely similar.
PostPosted: Jan Wed 10, 2018 2:53 pm
That device is a Monolithic Microwave Integrated Circuit (MMIC).
Here is a practical intro to MMICs:
http://www.arrl.org/files/file/Technology/microwave/8702023.pdf
There are a number of companies producing MMICs, like Mini Circuits:
https://www.minicircuits.com/WebStore/Amplifiers.html
http://www.om3bc.com/datasheets/MMICSb.pdf
Based on the gain/frequency specs of the module it is not any of the Mini Circuits MMICs .
https://www.ebay.ca/itm/RF-Wide-Band-Amplifier-30dB-High-Gain-Low-Noise-LNA-Amplifier-Module-0-1-2000MHz/122818087090?hash=item1c988748b2:g:vcUAAOSwonBaEjwu
Peter
PostPosted: Jan Wed 10, 2018 3:13 pm
HP/Agilent Data Sheet. INA-02184 and INA-02186 (marked NO2).
http://www.qsl.net/n9zia/metricom/ina02184.pdf
Generally use a 5 VDC supply and it will draw about 30 mA. You should never exceed 8 VDC.
Curtis Eickerman
PostPosted: Jan Thu 11, 2018 8:48 am
You guys are the best! Thank you all so much for helping me out here. I'm a tube guy and my knowledge of semiconductors ends with designing low voltage power supplies. Curtis, you are the man. I'm totally impressed you found this thing. I thought it might work in a balanced RF amp for a loop antenna I'm working on. Now on to the data sheet............
