It is currently Jan Wed 16, 2019 7:11 pm
 Post subject: Unused transformer secondary ... bucking transformer?
PostPosted: Jan Thu 11, 2018 1:32 am
Hi all,
I'm wondering how feasible it would be to use half of the 25v winding shown here as a bucking transfomer, to bring the incoming AC down 12 volts or so?
 Post subject: Re: Unused transformer secondary ... bucking transformer?
PostPosted: Jan Thu 11, 2018 2:48 am
Greetings to Diverted and the Forum:
It might be possible, however.... the heater current for a 25Z6 is .3 amperes. This is probably what the wire used to wind this particular secondary is sized for. Three-tenths of an amp at 120 volts is only 36 watts. If your radio is rated at more than that, it will draw more than .3 amps.... and likely over-temp that filament winding.
Regards,
Jim T.
KB6GM
PostPosted: Jan Thu 11, 2018 5:05 am
Not clear what you intend to do here. How are you going to get half of the 25-volt winding? It's not tapped according to the schematic.
Thomas A. Edison
