It is currently Jan Wed 16, 2019 7:27 pm
 Post subject: Talking House 5 external antenna
PostPosted: Jan Thu 11, 2018 2:23 am
I recently purchased a Talking House 5 and am quit pleased with its audio quality. The question I have is what is a good external antenna to use? I'm not looking to increase my range, that would be ok, however, my main goal is to keep the RF away from the immediate area around the transmitter and my audio sources.
Just looking for a few suggestions.
Tony
People may not remember how fast you did a job, but they will remember how well you did it.
PostPosted: Jan Sun 28, 2018 9:44 pm
And are you talking local or DX?
What have you room for, why cant you have a wire AND a vertical?
 Post subject: Re: Talking House 5 external antenna
PostPosted: Feb Fri 09, 2018 9:05 pm
Really?
A "good antenna" will do just that- increase your range, which is governed by part 15.2XX emission rules...this may help (see attached links) explain the FCC's intent. You are limited to 3 meters total, radiator and 'ground' combined, as I understand it. If you need to move the radiator away from other devices, I would imagine that a coax feedline to a 'radiator' located elsewhere would not be effective nor legal, as the entire coax shield would then be in effect a part of the radiator/ground design as well.
http://www.talkinghouse.com/faqs.htm
Todd
ka8gef
'Itoshiki oshieo idaki'
PostPosted: Feb Fri 09, 2018 11:03 pm
With a short antenna, good matching makes all the difference. Here's a simple ckt tuned to 1540 Khz
Capacitors are variable, coil is ferrite toroid (for self shielding).
