It is currently Jan Sat 19, 2019 8:07 am
 Post subject: Popular Electronics 1955. Build a 1 Tube Radio 1D8-GT
PostPosted: Jan Sat 27, 2018 10:59 am
Hi Folks, I’m building a one tube radio using the 1D8-GT. I’m excited about building this because of the Diode-RF-Power Output !
Have read up on this and wasn’t aware of the popularity of this tube. If anyone is interested the article Pop Tronics November 1955.
Thanks Tony
 Post subject: Re: Popular Electronics 1955. Build a 1 Tube Radio 1D8-
PostPosted: Jan Sat 27, 2018 1:44 pm
Are you sure it was Nov 1955, the only one tube receiver I found is on page 43 and uses a 6AU6
http://www.americanradiohistory.com/Arc ... 955-11.pdf
Eddy
PostPosted: Jan Sat 27, 2018 2:16 pm
It's in the October 1955 magazine page 51
http://www.americanradiohistory.com/Arc ... 955-10.pdf
Eddy
PostPosted: Jan Sun 28, 2018 12:52 am
Here's a July 1940 article in Radio Craft magazine for another radio (page 42) using the same 1D8GT tube. http://americanradiohistory.com/Archive ... 940-07.pdf
I used a pair in my "Batman" battery powered cigar box guitar amp. This is the faux sales flyer for it.
PostPosted: Jan Sun 28, 2018 1:00 am
diode triode pentode three tubes in-one super one tube radio with speaker
PostPosted: Jan Sun 28, 2018 8:51 am
About 1964, when I was 14, I discovered my Dad's stash of circa 1940 radio books. One of them had an article about building a radio with the 1D8GT, another was designed around HIVAC midget tubes as I recall. I haven't yet found a 1D8GT. I found some midgets, but not the sockets for them. I finally gave up on building after realizing I don't really have the knack for it.
PostPosted: Jan Sun 28, 2018 2:42 pm
dont give up. practice makes perfect as they say. gathering the parts is the big challenge. this radio is an interesting design with diode, triode and pentode in the same tube. I am no expert but should work really well together. diode detect, triode pre-amp and pentode power amp to drive a speaker. it is really a three tube radio
https://vacuumtubesinc.com/index.php/va ... 1d8gt.html
PostPosted: Jan Sun 28, 2018 3:17 pm
A 3A8 tube will do as well with 1.4 volts (and take a little more B+ if needed)
Dale
PostPosted: Jan Sun 28, 2018 4:46 pm
Hi Folks, I am missing one part, once I grab it I can start building, I’m looking for a ( 3-30 Mica Trimmer Cap ).
As a side note has anyone heard of a “Service Note “ for a Heathkit scope model 0-8.
Thanks Tony
PostPosted: Jan Sun 28, 2018 8:45 pm
I believe that 3-30 pF is for trimming the antenna
the radio should work without it
you should be able to add it later easily
PostPosted: Jan Sun 28, 2018 8:49 pm
Hello guys,
that looks like a fun project
PostPosted: Jan Sun 28, 2018 10:34 pm
Thank you for the info, will start the build and add the trimmer later.
PostPosted: Jan Sun 28, 2018 11:39 pm
Interesting radio. The schematic.
PostPosted: Jan Mon 29, 2018 3:37 am
Ya looks really interesting will start to build soon !
PostPosted: Jan Tue 30, 2018 5:32 pm
Meh, I’d be more interested if that triode did some RF amplification.
Scott
PostPosted: Jan Tue 30, 2018 5:42 pm
Could add a coil in the plate circuit for regeneration? When I built this radio didn't find the diode connection made any difference.
PostPosted: Jan Tue 30, 2018 6:39 pm
Norm, any chance a small AA5 antenna could replace the slug tuned coil?
I assume the little Radio Shack audio output transformer would work. (Secondary: 8 ohm
load): 1K ohm)
Tube ordered.
PostPosted: Jan Tue 30, 2018 6:45 pm
Could use a coil from an AA5 but still need an antenna unless in a strong signal area.
1D8 should feed into a 12,000 ohm impedance. A Radio Shack 1K to 8 ohm will work but not the most volume. Notice they used outside leads on a push-pull transformer. This gives higher impedance.
PostPosted: Jan Tue 30, 2018 7:01 pm
Then this Bogen T-725 using wh/blk will have to do.
PostPosted: Jan Tue 30, 2018 7:28 pm
p/p as single ended
