It is currently Feb Wed 20, 2019 2:45 pm
Post New Topic Post Reply  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Popular Electronics 1955. Build a 1 Tube Radio 1D8-
PostPosted: Jan Wed 31, 2018 10:29 am
Thank You to everyone for taking the time to help with information and more. I will this project within a few days, when I’m done I will post pics.
Tony
PostPosted: Feb Fri 02, 2018 7:15 pm
Forgive me if this has already been pointed-out, but the original design was all about utilizing all three parts of the "3 in 1" tube, and not about maximizing radio performance.
The same tube will make a much hotter radio when the triode section is used as a reginerative detector. Forget about the diode .section.
Should be pretty easy to modify the original to make a regin after it's built and checked-out.
Ted
PostPosted: Feb Sat 03, 2018 2:04 am
You could use that diode with a regen. There's some information here:
https://www.radiomuseum.org/forum/proje ... eiver.html
Scroll down past the regen project to Joe Sousa's comments (a little past halfway),
'Optimized amplifier-detector and regeneration methods'
The idea is to use the diode as the AM detector before the regenerative amplifier. With a triode, this lets you raise the voltage on the detector and thereby get more audio gain. Also, a diode can handle much stronger signals than a regen's gridleak detector.
There's another reason: the AM sensitivity of a diode is said to be greater than that of a gridleak detector's cathode to control grid 'diode'.
Anyway, it's something to experiment with. To begin with, just connect the diode plate to the regen's control grid.
Another direction: perhaps the diode could be used as a simple shunt noise limiter between the detector stage and the audio amp.
Rob
PostPosted: Feb Sat 03, 2018 11:44 pm
Mike Toon wrote:
Then this Bogen T-725 using wh/violet will have to do.
PostPosted: Feb Sun 04, 2018 2:21 am
Very true, but I had the misfortune of growing up just outside of KSTP's (AM 1500, 50kW) 1V/m blanketing contour. Any simple circuit radio would pick up just that one station at worst, or at best it would still bleed over any of the others I could hear. Hence I've always had a disdain for circuits that didn't somehow maximize performance. No sense in building a radio just to hear something I wasn't interested in.
Scott Todd
PostPosted: Feb Sun 04, 2018 1:05 pm
you should introduce your true circuit for comparison :)
