It is currently Dec Wed 19, 2018 2:46 am
 Post subject: 96MHZ PLL locked FM transmitter Schematic
PostPosted: Mar Thu 01, 2018 11:34 pm
Full article by me
https://electronicsforu.com/electronics ... ransmitter
 Post subject: Re: 96MHZ PLL locked FM transmitter Schematic
PostPosted: Mar Fri 02, 2018 12:44 am
https://imgur.com/a/1qKFP
Schematic
PostPosted: Mar Fri 02, 2018 3:59 pm
If used with a 1 Watt amp as suggested in the article this transmitter is illegal in the US, and that is likely the case even without the amp.
Dale H. Cook, Radio Contract Engineer, Roanoke/Lynchburg, VA
http://plymouthcolony.net/starcityeng/index.html
PostPosted: Mar Fri 02, 2018 4:10 pm
This article was published in South Asia.
The power input to the oscillator can be lowered and with a proper
Low pass filter it would be legal in the US.
PostPosted: Mar Fri 02, 2018 9:28 pm
You cannot simply assume that it is legal. Have you conducted field intensity measurements that would be acceptable to the FCC?
