It is currently Sep Tue 25, 2018 11:59 pm
 Post subject: Bluetooth Passive Amplifier
PostPosted: Mar Mon 05, 2018 1:19 pm
I have a number of working Grundig stereo consoles and was just building a few bluetooth connectors so that I can connect my phone via bluetooth and play music through the old stereo. I've been following this schematic with good success:
I have a Grundig KS 752 (https://www.radiomuseum.org/r/grundig_ks752u_ks_752_u.html) that works perfectly with the above passive amplifier. This stereo is a solid state version.
I created two more passive amps for other non-solid state stereos (https://www.radiomuseum.org/r/grundig_musikschrank_so302usso_30.html), but the sound sounds as if the gain is turned all the way up. There's some distortion, but the sound level is good. I suspect that I need to add a resistor to each channel on the output side.
Any guidance on if resistors are need and what value or what the problem might be?
 Post subject: Re: Bluetooth Passive Amplifier
PostPosted: Mar Wed 07, 2018 3:41 am
Could try this other circuit.
Burl Ives, RIP, oldtimer.
[:l>)
