The circuit as drawn doesn't work for VGA.
I'm not exactly sure I have it wired right, but I really don't have any composite source to test it with other than an Interface Technology 553 bus analyzer at work.
I thought that I could feed he vertical and horizontal sync signals to the transistors that generate the sawtooth waveforms, but apparently not.
I will test with that composite signal tomorrow just to see if the circuit is working right.
If it is then I need to figure how to feed the vertical and horizontal sync to the sync separator chip.
If not then I need to double check my work and see where I screwed up.
Looking at the data for the sync separator chip
http://www.ti.com/lit/ds/symlink/lm1881.pdfI will need to increase the value of the 680K resistor for it to properly handle a VGA signal.
1 meg according to the data should work.
So what I need is a circuit that will combine the video signal along with the vertical and horizontal sync.
http://www.nexusuk.org/projects/vga2scart/circuitThird picture
http://www.nanohawk.com/orange-pi-zero-and-vga/EDIT:
Got to looking after I measured 12Vdc B+ from a 7809 regulator and saw where I did not ground the ground pin of the regulator.
That fixed the vertical, but the horizontal is still messed up.
EDIT 2:
Found the AD8032 wasn't connected to ground nor was pins 1, 2 & 5 tied together.
Finally gfot it working halfway decently off a composite signal, but there's some issues.
Think I'm going to need shielded wiring for all the internal signal wires and also I might need to address the grounds as I had to conenct all three grounds from the cables going to the X/Y monitor in order to get the best display.
Also I had to insert a capacitor in series with the vertical and horizontal outputs which didn't affect the display any that I could tell.
This presents a problem.
My Tek X/Y monitor only has two internal switches to set the gain between two levels far as I know so I will need to add level control pots to the output of the circuit.
Would two 10K pots work or should I use a larger value?
EDIT 3:
I tried a 10K pot on the vertical and the output looked screwed up so I disconnected the ground from the pot and the image cleaned up a good deal more so apparently the evrtical circuit with the .1uF cap was being affected by the cable on the vertical out.
So I will need to add a buffer.
For the TV frequencies I am thinking perhaps a TL-082 will work.
I will have to suss out the VGA Monday.
Concerning the TL-082 I need to measure the output voltage of the vertical and horizontal to see what the peak to peak is so that I know if 9Vdc is fine for the op-amp or if I need a higher voltage.
Now it is possible for me to get a 7909 which will give me a dual supply for the op-amp and eliminate the need of coupling caps on the output.
That said I am tempted to just build the circuit in the Tektronix X/Y display, although I don't think I have the room to do so. I could use panel mount trimpots or PC board trimpots for the controls. Then again I want this to be able to be connected to any scope with a Z axis input so it being in a separate box is just fine.
I am going to try shielded wire for the inputs, outputs and all wiring to the intensity and contrast pots just to see if it cleans up the signal any further, although it is looking real good as is and is possibly as good as it is going to get.
Concerning the vertical and horizontal sync lines from the VGA connector I will try the resistor method first to combine them then feed that to the sync separator chip.
I then reduce the switch to a DPDT or if I wanted to mix the sync with the VGA video a SPDT switch.
Also will replace the RCA jacks with BNC jacks except the composite video input which will remain RCA since most common composite video outputs are RCA jacks.
