It is currently Feb Sat 16, 2019 2:45 pm
 Post subject: CD as a radio dial
PostPosted: Jan Sun 28, 2007 6:20 am
I made a hub for a CD on my lathe. The intent is to use this a dial for a home brew.
This is turned from aluminum rod on my little Harbor Freight lathe. Setscrews hold it to a 1/4" shaft and two 4-40 screws hold the CD to the face of the hub.
http://antiqueradios.com/albums/Misc/CDdialBkr_80.jpg
http://antiqueradios.com/albums/Misc/CDdialFr_80.jpg
 Post subject: Re: CD as a radio dial
PostPosted: Jan Sun 28, 2007 6:24 am
Rivets would be nice.
Syl
PostPosted: Jan Sun 28, 2007 7:04 am
I have used the clear plastic "protector" that comes on some CDs. I especially like the small 3½" CDs. This is a crystal radio (actually hidden amplified) with a clear "CD" with a moveable indicator and stationary dial scale. Rubber grommet makes a tight fit over the red button (actually a water heater pilot button) Dial string behind controls it.
PostPosted: Jan Sun 28, 2007 8:18 am
Now you're talkin!
Great job, Rich.
I'm now using wood and found that my cap shafts are so short that I had to recess the screw heads.
On the CD itself, I've mounted screws like in your second photo, but the heads stick up so much that I think I'll need to put holes in the CD label.
Beautiful job. Let me know if you plan to sell these.
Macrohenry
PostPosted: Jan Sun 28, 2007 1:23 pm
Beautiful work, Mike.
PostPosted: Jan Sun 28, 2007 6:57 pm
Rich, Mike, (et al)...
Examples from both Members, nicely done...The pics illustrating Rich's hub and dial assembly are very Collins(esque)...Reminds me of some surplus logging scale dials I had from a Collins KWS-1...Very similar.
Bruce
WC5CW
PostPosted: Jan Sun 28, 2007 10:48 pm
That's a really cool idea. I always like to see new uses for otherwise boring stuff.
What else I think should be mentioned is that you have the benifit of all the precut CD labels and software which will make it easy to make scales for this method, too.
Perhaps a threaded hub (I dunno how) and a little retainer nut from a switch to hold the CD in place?
tdkask
PostPosted: Jan Sun 28, 2007 10:59 pm
Silent Key
It is one heck of a better idea for them than what I have used them for! And I think most of you may know what that is! One clue for the newbies....it involves 100 yards.
Curt
Curt, N7AH
PostPosted: Jan Mon 29, 2007 1:27 am
Speaking of software for making dial scales...
I use GraphPaper. It's really neat for making circular scales and you can put divisions and tick marks as you wish. You can also make any number of degrees in the scale, so you can use it with pots, switches, variable caps, etc. I think it's still available via the Internet from Metz in France. You can also make your own log paper and Smith charts with it.
See issue #160 of Electric Radio for an article I wrote regarding making new scales for dials and analog meters.
[/url]http://perso.easynet.fr/~philimar/[url]
Users browsing this forum: Dennis Banker and 3 guests
