Page 1 of 1
[ 4 posts ] |
| Author |
dodgerm37b1
Post subject: Wallensak recorder Posted: Apr Sun 08, 2012 1:22 am |
What is used for a replacement power cord on a Wallensak 1520AV? The lower pin on this recorder is grounded. Any help will be appreciated. Thanks, Bob
| Top |
Fred Longworth
Post subject: Re: Wallensak recorder Posted: Apr Sun 08, 2012 6:56 am |
Joined: Jun Fri 22, 2007 12:54 am Posts: 680 Location: San Diego
Unless I misunderstand your post, the AC jack is a three-wire (AC line + ground) arrangement, that has an oddball form factor.
Usually, when the connector is really weird (read "unobtainium") I'll look in the Mouser catalog, and order a modern three-wire jack and corresponding three-wire cord. It takes a little machine work, but in the end it is a lot safer than using some 40-plus-year-old cord I find on eBay.
NOTE: When I do this, I use machine screws with nuts and lock-washers to hold the new jack onto the chassis. I do not use self-tapping machine screws, as they can rip loose under stress. I use locking compound on the nuts. I'm very concerned that under heavy stress that my new jack assembly not come loose. Sometimes I augment the screws with JB Weld.
Fred owner Classic Audio Repair
_________________ www.repairaudio.com
| Top |
radiotechnician
Post subject: Re: Wallensak recorder Posted: Apr Mon 09, 2012 12:44 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 3937 Location: Powell River BC
The Wollensak T1500 series are classic recorders and can be seen in movies. Keep looking.
| Top |
Mr. Detrola
Post subject: Re: Wallensak recorder Posted: Apr Mon 09, 2012 12:55 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 18121 Location: Detroit, MI USA
The same type of power cord was used on some office machines in the 50's and 60's. They are not impossible to find, but of course when you need one then it will seem like it takes forever. I have found them from time to time in boxes of assorted cords at flea markets or in thrift stores.
_________________ Dennis
| Top |
Page 1 of 1
[ 4 posts ] |
