It is currently Feb Fri 22, 2019 3:15 pm
 Post subject: Wurlitzer 510 amp
PostPosted: Sep Fri 05, 2003 7:34 pm
This is from a Wurlitzer 1250 jukebox . Can someone find this schematic for reference ( i already have one )<P>Is this an odd amp ? hooking a CD player to its input gives very low volume results . Hooked to its original phono cartridge it plays low volume .<BR>I have checked & swapped tubes and recapped the amp .. still low volume <BR> <P>------------------<BR><BR>
PostPosted: Sep Sat 06, 2003 8:56 pm
Holy smokes it would take longer to draw that than it would to restore the whole jukebox ..thanks .. :-)<P>I figured it out , the junction box was needed to bring the tube filaments up to full power .<P>------------------<BR><BR>
PostPosted: Sep Mon 08, 2003 6:12 am
Wouldn't that amp be set up for a zenith cobra cartriage? If so, I don't believe it would operate properly with the feed off of a cd player. I have the 1400 and tried to test mine out that way and learned that it doesn't work right. Something about how the zenith cartriage works. I'm sure someone here can get technical and explain it.<P>Bill<P>------------------<BR>
PostPosted: Sep Mon 08, 2003 4:50 pm
The Zenith "Cobra" pickup has a small coil and a stainless-steel vane, which is welded to the stylus. The pickup coil is part of an oscillator which operates at 2.5 Mhz. Modulation of the record grooves causes corresponding variations of the Q of the pickup coil, which varies the output of the oscillator. "Plate bend detection" occurs in the oscillator tube, providing an AF output. This information comes from an old Zenith service manual, for the S-11680 record changer. If another audio source is to be connected to a phonograph using the Cobra pickup, it would need to be connected to the output of this oscillator stage.<P>Tim <P>------------------<BR>
PostPosted: Sep Mon 08, 2003 10:11 pm
If this amp is set up for a Cobra tone arm with the circuit Tim describes you may have to use a preamp to bring the signal up to the level the oscillator would have put out. You would have to bypass the oscillator circuit, and feed the output of the preamp to the first amp tube. The preamp would also supply the RIAA equalization needed. <P>Dave<P>------------------<BR>
PostPosted: Sep Mon 08, 2003 10:24 pm
PK<BR>I would think a PA amp would be a poor choice for a guitar amp because of the very low passband and the non linear frequency response. The response on a PA amp usually drops off after 5khz. The complete circuit would have to be redesigned to widen the passband but then you would still be restricted by the small output transformer which is not designed for the higher frequencies.If you have worked out a system for doing this I would be interested as I have a couple of PA amps sitting here collecting dust.<P>Dave<P>------------------<BR>
 Post subject: Re: Wurlitzer 510 amp
PostPosted: Jan Mon 15, 2018 8:10 pm
If I am reading this correctly, are you saying you DO have a schematic for a Wurlitzer 1250? Would you be willing to scan or share it? Or sell it to me cheaper than I can find it in cyberspace?? Thank you!
Diane
PostPosted: Jan Thu 25, 2018 3:03 pm
http://www.verntisdale.com/schem/510.jpg
Users browsing this forum: Giulio Maiocco and 4 guests
