It is currently Jun Thu 21, 2018 5:18 am
 Post subject: Heathkit FM-4 tuner
PostPosted: Feb Thu 15, 2018 4:46 am
I got mine today. USPS smashed the package but it was double packed
and the inner package was fine.
I ran it up on a variac and dim bulb and it sounds fine on 2000 ohm
headphones (which is how I frequently used it in high school .)
If this gizmo gets recapped it will need axial electrolytics. Has anyone used the axial
ones from JustRadios? Are they reliable? What do they look like? How big
are they compared to the originals?If too different I might restuff the originals with
the radial caps I stock.
I've got
a good schematic but no manual (for alignment, though except for the tuner
its very generic.) Does anyone have a full manual?
I never found one online.
 Post subject: Re: Heathkit FM-4 tuner
PostPosted: Feb Thu 15, 2018 3:43 pm
For comparing you can get size data on electrolytics on tubesandmore site. SAMS link below for alignment if this is what you need.
Bill J.
https://app.box.com/s/z0hbb1sck1y5dh7w2npjlrbl2wc8tbkz
PostPosted: Feb Fri 16, 2018 3:54 am
I recapped my FM-4 using radial electrolytics and an axial film cap for the
output. All the radials fit under the chassis.
After alignment by the book it worked fine on non-HD stations but
on HD ones was bad. I realigned just the ratio detector can using a scope
on the multiplex output, rocking the tuning knob back and forth. After I aligned
for complete symmetry of the appearance of the HD signal about zero
volts (using both slugs) it works fine on all stations now. By the book this
was very unsymmetrical.
Fidelity and sensitivity is much better than the FM-3. One of my
two favorite classical music stations is HD.
Note that I claim the HD in HD Radio stands for "horrible distortion".
PostPosted: Feb Fri 16, 2018 10:15 pm
An oddity I noticed last night.
The schematic specifies a 300 antenna. The connection to the tuner is 300
ohm twin lead.
But the schematic says one side is grounded at the tuner!
And a simulator says that the impedance is 100 ohms!
In other words, its a good match for 75 ohm coax!
WHY ... other than that 300 ohm was "expected" back in the day?
Its quite true that the thing will only receive the strongest signals
if a 1/4 wave long wire antenna is connected to the grounded terminal.
PostPosted: Feb Tue 20, 2018 11:21 pm
You are right. So much garbage intentionally added to FM signals these days. I remember the good old "pure signal" days.
KN4GGM
"This is the last radio I will ever buy, dear; I promise"
PostPosted: Feb Thu 22, 2018 11:33 pm
The FM-4 is one of my daily drivers (I have two.) Both have been recapped with Just Radio caps, no problem. I also converted both rectifiers to FW as I hate 1/2 wave on principle! Both were realigned "by the book" with a 10.7 MHz sig.gen. and VTVM, no scope used... results very good, nice tuners.
Good luck,
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Feb Thu 22, 2018 11:41 pm
..... I might restuff the originals with the radial caps I stock.
Why do say "it will need AXIAL electrolytics"?
You can just use the radials you have in stock. Remember the two leads do not need to connect to the same location as before. Only the positive leads go to the same place but the negative lead can be soldered to the nearest ground point.
cron
