It is currently Jun Sun 24, 2018 12:28 am
 Post subject: Fisher 500C - Service manual for #70222
PostPosted: Feb Fri 23, 2018 11:32 pm
Anyone have a Fisher service manual for the 500C, covering serial 70222? The published manuals I find easily online cover 30001 - 49999. It's pretty close, but there are some different values in the bias circuit and the unit I'm working on has been "messed with" in that area before I got to it, and it isn't clear what's original and what's new.
 Post subject: Re: Fisher 500C - Service manual for #70222
PostPosted: Feb Sun 25, 2018 2:35 am
Add four 10 Ohm resistors - cathode to ground for each output tube so that you can measure current. The bias circuit resistors can be changed to get 300-350 mV - 30-35 mA per tube. If you get that, the resistors are RIGHT, regardless of what any manual says. (of course, if they're not equal, you need some new output tubes).
PostPosted: Feb Mon 26, 2018 3:08 am
+1. I just had a 500C a few months ago and added the resistors. It was a lower serial number than yours so I could use the online manual.
ex nihilo nihil fit
PostPosted: Feb Wed 28, 2018 4:50 am
Yeah, sounds good, I'll do that and then adjust the fixed resistor to give a reasonable current across the 10 Ohms. Thanks for the notes.
