It is currently Jun Thu 21, 2018 3:14 pm
 Post subject: Denon AVR-2803 Output Problem???
PostPosted: Mar Fri 16, 2018 7:36 pm
I have a Denon AVR-2803 AV Receiver that has no output with speakers connected.
If I connect headphones I have left/right output. Do I have something not set right or
are the output transistor/s gone???
 Post subject: Re: Denon AVR-2803 Output Problem???
PostPosted: Mar Fri 16, 2018 9:39 pm
Most likely your output transistors are good. You can download the service manual for your receiver for free from Hi Fi Engine. All you need do is register and it won't cost you a dime.
Jim
KE8GMW
"AC volts and DC volts and little lamps and lities..."
PostPosted: Mar Fri 16, 2018 10:03 pm
The owners manual is also available on Hifiengine. No audio from speakers can be caused from the mute level on and set too high, headphones inserted or the master volume level set low.
If there is a problem in the set it could be poor connections on one or more of the circuit boards, especially where they connect to each other.
PostPosted: Mar Sun 18, 2018 2:11 am
Thanks for the advice
I opened the cabinet, took the boards out that I could, cleaned the connections and reinstalled.
It works great !!!!
PostPosted: Mar Mon 19, 2018 10:09 pm
It works great !!!!
Great news, congratulations.
Users browsing this forum: Majestic-12 [Bot], Rockbert and 5 guests
