It is currently Oct Thu 19, 2017 8:49 pm
 Post subject: WTB: Film capacitor FOUND! please lock
PostPosted: Jul Sat 15, 2017 3:48 pm
Again, this is a long shot…
I bought a bunch of these from a vendor at a hamfest (perhaps the Indianapolis hamfest) a number of years ago.
I'm trying to stuff a cap box in a Zenith 2037 chassis which held two 8 uf 500V electrolytics. I would rather NOT use electrolytics.
I found these ASC capacitors fit the bill. If I pile 12 of them with 6 X 6 side by side, they JUST FIT! This gives me two 8.4 uf @ 600V caps!
I need some more, would anyone happen to have a bunch? I could use 20 at a minimum.
They measure 12mm X 24mm X 33mm in size. ( 0.472 inch X 0.994 inch X 1.299 inch)
Can anyone help me find some?
I tried ASC's website, but no dice...
 Post subject: Re: WTB: Film capacitor
PostPosted: Jul Sat 15, 2017 3:50 pm
What's the ripple current rating on those film caps?
Different caps are meant to perform different functions, for a reason.
73 de Leigh W3NLB
PostPosted: Jul Sat 15, 2017 4:02 pm
These may be of interest:
http://www.ebay.com/itm/2pcs-NEW-MLC-SB ... SwTf9ZRKFq
6 would give you two 9.9uF caps for $42, however 15mm may be to thick for your application.
Eddy
PostPosted: Jul Sat 15, 2017 4:17 pm
Oh, those would be great! But a bit too pricey. Still, I'll consider it.
Leigh, the closest cap I find on ASC's website has similar hight and width, but slightly more length (which kills the application) and is rated at 2.7 amps.
Quite a bit better than any of the Asian grade electrolytic caps most people are using as filters in these old radios.
These are overkill, I admit.
PostPosted: Jul Sat 15, 2017 4:22 pm
These might do it;
http://www.ebay.com/itm/10-Ea-Electrocu ... SwdzVXrT0j
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Jul Sat 15, 2017 4:28 pm
Those are 400 VDC rated, not 600.
Also the ones Eddy posted have 2 pcs in the title, but say 1 pc in the description.
I don't know which to trust, and comes straight from China.
PostPosted: Jul Sat 15, 2017 5:43 pm
I know somebody with a bag full of 1uf 600 volt film caps of a similar shape. PM me for an email
I know you rather not use elrctrolytics but you can stuff two 22uf@250v electrolytics in series to net 11uf@500v if the extra 3uf won't hurt the circuit.
Sal
Need capacitors, resistors and other parts--> http://www.tuberadios.com/capacitors
PostPosted: Jul Sun 16, 2017 1:54 am
I have some cylindrical 10 uF caps @ 1KV, but is 1 3/8" x 2 1/2" too big?
PostPosted: Jul Sun 16, 2017 2:04 am
Apex JR lists 3mf 600v mylar caps, mfd by Elpac. Might be worth inquiring about their dimensions.
http://www.apexjr.com/capacitorA.html
-Chuck
PostPosted: Jul Sun 16, 2017 4:04 am
http://www.mouser.com/ProductDetail/Vis ... nP8w%3d%3d
Will these fit .
http://www.mouser.com/ds/2/427/mkp1848c ... 461049.pdf
Mark
PostPosted: Jul Sun 16, 2017 7:41 am
If at all possible, I like to use film caps rather than electrolytics under 600VDC as well.
Very good luck is had with the Solen & Andrea products so far, both for restuffing and original designs.
The nice things are very long life and better heat resistance.
DDG
There's a reason it wasn't Werewolves of Lubbock....
 Post subject: Re: WTB: Film capacitor FOUND!
PostPosted: Jul Mon 17, 2017 1:04 pm
battradio@ wrote:
http://www.mouser.com/ProductDetail/Vishay-Roederstein/MKP1848C61090JP4/?qs=sGAEpiMZZMv1cc3ydrPrF6VKmnbjjATPH91yaa2GzQrSg8rPZNnP8w%3d%3d
Will these fit .
Yes! They indeed will fit! Excellent! Thank you, Mark!
Caps are on order, Please lock this thread! :D
Post New Topic Post Reply  [ 13 posts ]  Moderator: Philco Fan
Users browsing this forum: Mike Bracey, sfox7076 and 18 guests
