It is currently Feb Mon 18, 2019 1:56 am
 Post subject: WTB: Philco Oscillator coil
PostPosted: Dec Sun 26, 2010 1:31 am
I am looking to buy an oscillator coil for a Philco Model 84. The Philco part no. is 32-1311. If anyone has a cross-reference book, I would be interested in knowing the number of the Miller and/or Meissner equivalent.
Thanks for your help.
Joe Connor
PostPosted: Dec Sun 26, 2010 11:13 pm
There is no Miller or other sub for that. You take the old one out, back off the osc coil on the form (its only about 22 turns or so) and wind new wire onto the form... the EXACT way it was done. Use #34 ga enameled wire, also called "magnet wire".
Not super hard to do, the trick is to keep some tension on the wire as you are winding. To do that, I place the wire spool on my lap and have it feed off there. the spool must rotate, you dont want the wire unspooling off the side of the spool, you will loose your tension.
this ailment is common on the Philco 60, 66, 84, 89 (and the 37-xx versions of those as I recall)
Mark Oppat
PostPosted: Dec Mon 27, 2010 2:07 am
Thanks, Mark. However, my problem is that some prior owner already removed the oscillator coil so I'm sort of stuck. Might you have something that would work?
Joe Connor
PostPosted: Dec Mon 27, 2010 4:37 am
Hi Joe. I probably have one. Is this coil about 1 inch or so in diameter and about 3 inches high? I have a complete set of coils from a philco 89.
PostPosted: Dec Mon 27, 2010 6:44 am
I wouldnt use the model 89 osc coil. First off, these all suffer the same problem, the insulation on the wire is crappy and the wire corrodes. The model 89's have even worse track record than the 84's. Also, I dont think they are the same. If it is the same, rewind it, dont use as is.
Mark Oppat
PostPosted: Dec Mon 27, 2010 12:38 pm
For an explanation of the why and how on rewinding the coil once you get your hands on one, see the following:
http://www.philcorepairbench.com/tips/svctip36.htm
Smokestuffer
Post New Topic Post Reply  [ 6 posts ]  Moderator: Philco Fan
Users browsing this forum: Als_Basement, ednspace, k2glo, Majestic-12 [Bot], RGuess and 10 guests
