It is currently Jul Thu 19, 2018 9:53 pm
 Post subject: FS: 50 Ohm Dummy Loads 5/10/25/50 Watt
PostPosted: Dec Thu 07, 2017 11:10 pm
I have a bunch of 50 Ohm dummy loads for sale. Shipping extra, from Norfolk, 23518. PayPal (F&F), claim and PM me your address for the total.
Prices and quantities available:
5 Watt Shively Labs - (1) available, $5
5 Watt Dielectric/Gen Signal (5) available, $5 each
10 Watt Dielectric/Gen Signal (5) available, $8 each
Thanks for looking!
Thanks for looking!
Brian
 Post subject: Re: FS: 50 Ohm Dummy Loads 5/10/25/50 Watt
PostPosted: Dec Fri 08, 2017 12:08 am
Greetings,
I'll take one each of these:
5 Watt Dielectric/Gen Signal (7) available, $5 each
10 Watt Dielectric/Gen Signal (7) available, $8 each
PM to follow.
Thanks, Terry
"Hardware eventually fails. Software eventually works" - Michael Hartung
PostPosted: Dec Fri 08, 2017 1:11 am
What's the frequency range on the 50-watt Bird?
PostPosted: Dec Fri 08, 2017 1:14 am
I'll take the 50W bird if Leigh passes.
Last edited by 4thDoctorWhoFan on Dec Fri 08, 2017 1:22 am, edited 1 time in total.
PostPosted: Dec Fri 08, 2017 1:18 am
Per the datasheet, DC-3.5 Ghz, with VSWR of 1:1.1 guaranteed to 1 Ghz. Upper is limited by the QC-N connector Bird uses on all their stuff.
Brian
PostPosted: Dec Fri 08, 2017 1:30 am
Findm-Keepm wrote:
...guaranteed to 1 Ghz. Upper is limited by the QC-N connector Bird uses on all their stuff.
But modern N connectors are good to at least 11 GHz.
PostPosted: Dec Fri 08, 2017 2:20 am
Bird used QC interchangeable connectors on nearly all their wattmeters and loads. You can buy them with traditional connectors too, but Bird wanted folks to have interchangeable connectors so that N-male could become a UHF Female with just a 4-screw swap. One guy has a business built on Bird stuff: http://www.nm3e.com/prod04a.htm - you can get a feeling of just how versatile their stuff is.
Me, nothing above 2.1Ghz with any appreciable power, so 11Ghz wouldn't be possible (unless I was merely measuring the freq with my 5351B counter with a munged faceplate.... :?
Brian
PostPosted: Dec Fri 08, 2017 3:50 pm
I'll take the 25 watt.
The lucky ones realize the "Good Ole Days" while they are still in them!
AA5LP
PostPosted: Dec Sun 10, 2017 1:02 pm
terryrh wrote:
Greetings,
PM to follow.
Thanks, Terry
Terry,
Still want them?
Brian
PostPosted: Dec Sun 10, 2017 5:30 pm
Yes-- I tried to send a PM but must have messed it up. PM on the way (I hope)!
Terry
PostPosted: Dec Sun 10, 2017 5:51 pm
I'll take a 10-Watt Dielectric, please.
PM coming.
Rodney -- KG7EPW
 Post subject: Re: FS: 50 Ohm Dummy Loads 5/10 Watt
PostPosted: Dec Mon 18, 2017 1:22 am
Bump. Only 5 and 10 watt types available.
Brian
Post New Topic Post Reply  [ 12 posts ]  Moderator: Philco Fan
Users browsing this forum: grid-leak, radiojwk and 14 guests
