It is currently Jun Sun 24, 2018 11:38 am
 Post subject: FOUND- 1100 Ohm Primary Impedance Audio Output Transformer
PostPosted: Jan Tue 23, 2018 2:54 am
I need an audio output transformer with a 1.1K ohm impedance to 3.2 Ohm secondary. It must be capable of handling 12W.
I am looking to spend not more than $20. Location, Alexandria, Virginia.
The primary should read about 70 ohms on a VTVM.
This is for a 1940's Westinghouse with parallel 6Y6.
Thank you.
 Post subject: Re: WTB 1100 Ohm Primary Impedance Audio Output Transformer
PostPosted: Jan Tue 23, 2018 3:01 am
Transformers do not have impedances.
They have impedance ratios.
The impedance (resistance) connected to the secondary sets the primary impedance.
In this case, the ratio would be 1100:3.2 = roughly 330:1.
PostPosted: Jan Tue 23, 2018 2:17 pm
Thank you, Leigh
So I am looking for a transformer with a 18:1 turns ratio?
PostPosted: Jan Tue 23, 2018 5:31 pm
Yep.
For anyone who didn't understand the question...
The impedance ratio is the square of the turns ratio
or alternatively
The turns ratio is the square root of the impedance ratio.
PostPosted: Jan Tue 23, 2018 10:19 pm
This Edcor should work, although there is a long lead time since they are made to order: http://www.edcorusa.com/xse15-25k
Having two 6Y6 in parallel will result in a total plate current of about 130 mA, which is a lot for a single-ended stage. That limits your transformer options. The Edcor above is rated for 130 mA, which doesn't give you any headroom. If you mention to Edcor your intended application, they may be able to modify the design to allow for a bit more current on the primary winding.
Also, note that the DC resistance of the primary need not be the same in a replacement transformer.
Matt
PostPosted: Jan Wed 24, 2018 1:43 am
Technically true, but they are all sold by plate load impedance, not turns ratios.
DDG
Workin' my Gramophone in a smartphone world.
 Post subject: FOUND WTB 1100 Ohm Primary Impedance Audio Output Transforme
PostPosted: Jan Wed 24, 2018 5:17 pm
No longer needed, thank you.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Philco Fan
Users browsing this forum: Google [Bot] and 7 guests
