It is currently Jan Wed 24, 2018 6:28 am
 Post subject: R-390 audio transformer replacement
PostPosted: Sep Wed 13, 2017 4:31 am
I have an R-390 and am looking at replacing the audio transformer which drives the audio filters.
In another topic it was mentioned the UTC A-24 would be a good replacement, but found I needed a UTC A-25 as that one is meant to have DC on the primary. The A-25 has a response of 40-20KHz.
I do not want to try and find one and pay the high price these go for.
What would be a good sub for that transformer and what would be a good sub with a 10K primary that has the same frequency response?
 Post subject: Re: R-390 audio transformer replacement
PostPosted: Sep Wed 13, 2017 11:27 pm
If you are talking about the R-390 communications receiver and you care about maintaining the original performance, the best thing would be to find a transformer from a parts set. Passive filters, whether they be LC, mechanical, crystal or ceramic, or any combinations thereof, are designed for specific input and output impedances. Replace the driver transformer with anything the factory didn't use or recommend and you'll probably get audio out of the radio but you are on your own as far as the filtering.
PostPosted: Sep Wed 13, 2017 11:43 pm
An utc O-8 or O-9 would work .
http://www.bunkerofdoom.com/xfm/UTC_1955_WEB/019.jpg
I have a couple of O-9s , if you have something to trade
Mark
PostPosted: Sep Thu 14, 2017 12:14 am
The transformer itself is good I just want something with a better low frequency response.
The 0-9 won't work unfortunately as it has about the same frequency response as the good originals.
PostPosted: Sep Thu 14, 2017 1:08 am
Why would you be worried about frequency response on a communications receiver, it was designed for optimal voice frequencies.
PostPosted: Sep Thu 14, 2017 4:45 am
Because I don't use it just for voice.
I often listen to it when I have my two tube transmitter fed the online feed of WRDV.
