It is currently Apr Sun 22, 2018 9:17 am
 Post subject: Banana Plug and Nut Fastener
PostPosted: Apr Mon 16, 2018 2:40 pm
Ive used this combination for panel attach and other mechanical holding and it may have application for some obscure radio application so I figured I'd share it. The Keystone 451 mini banana plug snaps into and snugly fits a 6-32 nut or standoff as shown.
http://www.keyelco.com/product.cfm/Bana ... ct_id/2365
Jeff-W3JKO
"Things are more like they are now than they ever were before" -D. Eisenhower
 Post subject: Re: Banana Plug and Nut Fastener
PostPosted: Apr Mon 16, 2018 5:38 pm
I think 6-32 is way too small.
PostPosted: Apr Mon 16, 2018 6:08 pm
The maximum inside diameter of a #6-32 nut is 0.1495 inches (actually a tad more).
The expanded diameter of the plug blades is 0.120 inches.
Probably a #4-40 nut would work.
PostPosted: Apr Mon 16, 2018 6:24 pm
Trust me youll never get the banana plug into a 4-40 nut. The nut and standoff in the pic is 6-32 and the rear of the plug screws into the same threads so unless it shrunk when I turned it around its 6-32. The internal thread minor diameter of Class 2-B threads at 6-32 is 0.114" so the plug at 0.120" un-sprung is a friction fit when inserted.
https://www.barnhillbolt.com/page/specs ... s2B100.htm
Jeff-W3JKO
PostPosted: Apr Mon 16, 2018 10:39 pm
I don't know what a Keystone 451 is, but I have short banana plugs that are standard size. There ain't no way you could get one inside a 6-32 nut. Maybe an 8-32 or 10-32, but I haven't tried.
PostPosted: Apr Tue 17, 2018 12:53 pm
https://www.digikey.com/product-detail/ ... ND/2170368
These are Mini Banana plugs
Its an excellent idea. I'll have to keep it in mind :D
Thanks Jeff!
