It is currently Apr Mon 23, 2018 8:04 pm
 Post subject: Where to buy grid connectors.
PostPosted: Sep Wed 25, 2013 11:48 pm
Where can I buy some grid cap/connectors? I can find ceramic caps but I just need either copper or tin clips.
 Post subject: Re: Where to buy grid connectors.
PostPosted: Sep Thu 26, 2013 12:21 am
Fuse clips (PCB or rivet style) will work in a pinch, at least for the octal (1/4") size. Oldradioparts.com has the old style clips.
PostPosted: Sep Fri 27, 2013 5:22 pm
I have used pieces of copper plated spring and seen regular spring stock used.
I expect an alloy of copper bronze spring would work fine too.
I have not yet tried the plated spring type fuse holders, but if the diameter is good,
. they should work fine
FrankB
WB7ELC
Member: TCA & Steel Soldiers.
" Break down the wall"
PostPosted: Sep Fri 27, 2013 5:44 pm
Fuse clips will work for the 1/4 inch caps.
I like to build my own on my lathe.
PostPosted: Sep Sat 28, 2013 12:49 am
You need to find a geezer close by with a drawer full of them. I
used one of these back in 1963, no wait , it was '61. :D
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Sep Sat 28, 2013 5:15 am
How many, what size(s) re you looking to find? Tom
