It is currently Sep Thu 20, 2018 2:23 pm
 Post subject: Low voltage Capacitors
PostPosted: Oct Thu 20, 2016 1:05 am
Where do you purchase your low voltage capacitors?
I need some small ones.
 Post subject: Re: Low voltage Capacitors
PostPosted: Oct Thu 20, 2016 1:42 am
Digi-Key and Mouser - look for 4 or 5mm diameter types from Panasonic or Nichicon.
http://www.mouser.com/Passive-Component ... geZ1yzxn99
4 Volts and up, values from .1uF to 220uF.
Brian
PostPosted: Oct Thu 20, 2016 5:36 am
Thanks so much. I wondered if there was someone doing capacitors for the transistor portable radio repair. I've used Mouser and DigaKey before. I usually work on tube radios but couldn't resist a nice, nostalgic GE P780, Thanks again
PostPosted: Oct Thu 20, 2016 7:05 am
Radio Shack also has a supply of 35 and 50 volt common value Electrolytic caps in both radial and axial configuration.
I recapped my P-780 sometime back. I think it only took two Electrolytics, but memory ain't that accurate. :wink:
PostPosted: Mar Fri 02, 2018 5:16 am
Newark Element 14. Great prices and no order minimum. Radio Shack if you can't wait. It was nice to see axial capacitors there.
Users browsing this forum: Google Adsense [Bot], Phonojim, WoodchuckTN and 4 guests
