It is currently Jan Sat 19, 2019 6:47 am
 Post subject: 450TH Transmitting Triode - A few questions.
PostPosted: Jan Mon 15, 2018 11:07 pm
I've found this beauty for a relatively low price, the guy who sold it still has a few of them in stock :D
It was apparently made in May of 1985 by the Brazilian tube manufacturer IVAPE - Indústria de Válvulas Eletrônicas Pecunha Ltda.
- There is a number inside the tube -- W410585 -- is this a date code?
- The filament seems to be hidden inside a small cylindrical cathode - Did Eimac ever make an indirectly heated version of the 450TH?
- And last question - Does the 450 (TH and TL) use tantalum plates like other Eimac tubes do?
Here are some photos of this little monster...
https://drive.google.com/open?id=1ywNwCXImp-MEBZxm2-os8CvOS9x9OHnDbQ
https://drive.google.com/open?id=1rw4uNXmewZ9ItRIcI2J_6-GrG0n0e4vSew
 Post subject: Re: 450TH Transmitting Triode - A few questions.
PostPosted: Jan Mon 15, 2018 11:16 pm
Tubes have a tantalum plate which operates red in use.
https://frank.pocnet.net/sheets/088/4/450TH.pdf
Never heard of an indirectly heater version of this tube. 450TH makes a nice display tube.
PostPosted: Jan Tue 16, 2018 2:52 pm
Thank you for the quick reply.
This tube also came in its original foam packaging, with a big "Ivape" logo on it.
Unfortunately I had to throw the foam away because it was in really bad shape.
There are no burn marks on the tube's envelope and no scratches on the aluminum base from the socket.
This makes me think it's NOS.
Very cool.
PostPosted: Jan Tue 16, 2018 6:18 pm
Take good care of it. Hams are still using them in vintage transmitters.
PostPosted: Jan Tue 16, 2018 7:54 pm
While early versions of the Eimac tubes do have tantalum plates, later ones have plates coated with a tantalum compound. The same compound is used to coat modern graphite plates, which is why they look gray instead of black.
Jim Cross
PostPosted: Jan Sat 27, 2018 6:56 pm
Heater is a spiral around a center post; the cage around it is the grid. Tube is worth its weight in gold.
Scott Todd
Users browsing this forum: 35Z5, mhuston26 and 11 guests
