It is currently Feb Fri 22, 2019 9:19 pm
 Post subject: What is This Called?
PostPosted: Jan Tue 30, 2018 3:25 pm
Is the a name for this type of selector?
This one has (10) resistors at 1K each.
decade switch?
Collecting audio gear and radios because I couldn't afford to buy it when I should have.
 Post subject: Re: What is This Called?
PostPosted: Jan Tue 30, 2018 4:07 pm
It is a rotary switch.
The 10 precision resistors suggest it's a voltage setting switch or a resistance standard switch.
That would depend on how it's wired and used in the circuit.
PostPosted: Jan Tue 30, 2018 4:08 pm
Things like that have various names depending on how they are used. Decade resistor probably, could also be an attenuator or a range selector. A lot would depend on how the rotating contact is arranged. If it breaks contact with one resistor before it makes contact with the next, it is probably audio or level related. A switch that makes contact with the next resistor before it breaks from the previous one would be more likely to be used in test equipment. But there are no hard and fast rules for this.
PostPosted: Jan Tue 30, 2018 5:17 pm
I've also called them wafer switches, because of the 'wafer' construction of the rotating mechanism.
PostPosted: Feb Fri 02, 2018 8:02 am
A decade switch has 10 possibilities Zero to 9 . It uses 9 resistors.
However, some commercial decades have a special contact arrangement and only
4 resistors.
The resistor values are 1, 1, 4, and 3. or 1, 2, 6, and 3.
So, consider that any value resistor, from 1 ohm to 999 ohm can be made
from only 12 resistors !
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Feb Tue 06, 2018 3:45 pm
Thanks for all the info!
Joe Y
