It is currently Feb Sat 23, 2019 6:35 am
 Post subject: 50 volt candelabra base indicator bulbs - what were they for
PostPosted: Jan Fri 26, 2018 6:12 am
Among a box of odd light bulbs, including some round neon medium-base bulbs with cross-shaped electrodes, I found what looked like standard globe indicator bulbs, except they were marked as 50 volts. I managed to hook a string of 3 together in series with clip-on sockets, perhaps to make an illuminated wall display or shadow box. Another possibility I thought of was getting three old candelabra-base Christmas light parallel strings, and putting them in series so I could use more bulbs.
At any rate, what were these used for? Railroad use, early traffic control panels? They are 50 volt, 5 watt bulbs. I'm just curious. Maybe I could use them as ballasts for series-string curtain-burners...
 Post subject: Re: 50 volt candelabra base indicator bulbs - what were they
PostPosted: Jan Fri 26, 2018 1:13 pm
They'd work as ballasts, but you'd probably need around eight in parallel...
PostPosted: Jan Fri 26, 2018 3:48 pm
Likely for use in a telephone central office with 48-Volt power.
Workin' my Gramophone in a smartphone world.
PostPosted: Jan Sat 27, 2018 6:46 pm
Most telco stuff was push-in slide base, but other than that the voltage would be about right.
Scott Todd
PostPosted: Jan Sun 28, 2018 5:21 pm
Series string lighting?
Sometimes the best part of this hobby is that i have a rock station at both ends of the band....
PostPosted: Jan Sun 28, 2018 6:21 pm
Teletype
PostPosted: Jan Sun 28, 2018 7:01 pm
Also railroad moving stock.
Pete
Users browsing this forum: pauls.ironhorse and 6 guests
