It is currently Jan Sat 19, 2019 7:03 am
 Post subject: 200 tube test data
PostPosted: Jan Sat 27, 2018 9:55 pm
I've got a 200 tube to check and can't seem to find test data for my Hickok 600A? I was hoping one of the gang here would have the correct data.
Dan
I know just enough to be dangerous.....
(Member - Michigan Antique Radio Club)
 Post subject: Re: 200 tube test data
PostPosted: Jan Sat 27, 2018 10:24 pm
Dan
Do not test 200 tubes on a Hickok tube tester. The 200 is a gas filled tube which ionizes with high plate voltage. A Hickok tester has too high of plate voltage for this tube so most will fail.
If your 200 has a good filament it will probably operate in a radio. I have picked up good 200 tubes from dud piles due to being tested on a Hickok.
PostPosted: Jan Sat 27, 2018 10:43 pm
Thanks for the warning Norm. I'll check the filament only.
Dan
PostPosted: Jan Sat 27, 2018 11:25 pm
The 200 (non-A) has a max plate voltage spec of 25 volts.
The max plate voltage for the 200A is 45 volts.
It's quite common to find ones that are bad / ionized due to previous owners' errors.
Once the plate voltage is exceeded, the gas ionizes. That cannot be reversed.
If you need one, I suggest buying only NOS ones from a knowledgeable dealer.
Vacuum Tubes Inc is a member here, and should be able to supply such.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Jan Sun 28, 2018 1:41 am
Fortunately the one I picked up today at the MARC show was NOS.
Dan
