It is currently Feb Sat 16, 2019 3:23 pm
 Post subject: Resistor proprietary color codes (1933 Emerson)
PostPosted: Jan Tue 30, 2018 7:11 pm
Looking at a 1933 Emerson 250AW - checking resistors. The color codes seem to make no sense. Has anyone documented what these mean?
 Post subject: Re: Resistor proprietary color codes (1933 Emerson)
PostPosted: Jan Tue 30, 2018 7:28 pm
15k for top one and 250k for the bottom one would "make sense" but without a schematic is only a guess.
I'm sure others more knowledgeable will be able to help you know for sure.
I must admit I've never seen resistors like this before, but could not resist guessing anyway. :D
73, de Chuck K4CCW
"The question is not what you look at, but what you see." Thoreau
PostPosted: Jan Tue 30, 2018 7:43 pm
Ya know - you might be right - one of the colors has an arrow pointing to the left. I was using that as a starting point. Let me re-check these.
Just checked - you must be right. The 3 or 4 that I checked seem to be over 80% off in value. Ugh - I was hoping they were good cause I like the way they look.
PostPosted: Jan Tue 30, 2018 8:00 pm
Those are Micamold brand resistors and are usually bad. Plan on replacing all of them.
What happens under the chassis stays under the chassis.
PostPosted: Jan Tue 30, 2018 8:05 pm
Good ol' Micamold :cry:
PostPosted: Jan Tue 30, 2018 8:08 pm
Micamold gets an A for consistency. All* of their parts are bad.
- Leigh
* with the exception of real mica capacitors, which are few and far between.
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Jan Wed 31, 2018 1:39 am
Mystery solved - and yet no one commented on the "Victory Beaver" cap in the foreground. Where in the heck did they pull that name out of? :mrgreen:
PostPosted: Jan Wed 31, 2018 12:17 pm
Time for a wild guess, if the capacitor is not original. During the second World War, there was a program to make parts with a limited number of values that could be used to replace virtually all old values. They were called the Victory line. Of course, that does not help make sense of Beaver.
PostPosted: Jan Wed 31, 2018 3:52 pm
You're right- it's a replacement part. It must have been put in during WW2. They just installed it parallel to the dead one. I've seen Beaver caps before but this is the first Victory Beaver I've seen.
PostPosted: Feb Thu 01, 2018 11:48 pm
I think that the Beaver capacitors were put out by Cornell Dubiler. They also had one called the Blue Beaver.
PostPosted: Feb Sun 04, 2018 7:09 pm
While we are commenting on things, how about just twisting the leads of parts together and soldering them.
PostPosted: Feb Mon 05, 2018 4:11 am
Yeah, I noticed that - must have been the new girl on the line. I've ordered all new resistors for this set. Hopefully I can replicate the twist. Probably don't even need to use solder. :roll:
Users browsing this forum: GlensterTX, Leigh and 4 guests
