It is currently Feb Sat 16, 2019 8:47 pm
 Post subject: H.P. Paeco Transformer info needed
PostPosted: Feb Sat 03, 2018 3:26 pm
I have acquired a number of Paeco transformers that have been removed from vintage Hewlett Packard test equipment and am trying to identify the ratings and specs on them.
I am checking to see if anyone has a catalog or spec sheets on any of this brand of transformers. And any info on this manufacturer.
Thanks in advance.
 Post subject: Re: H.P. Paeco Transformer info needed
PostPosted: Feb Sat 03, 2018 8:42 pm
Greetings to jadedavid and the Forum:
As far as I know, Paeco was a subsidiary of HP. All of their transformers were made specifically to HP requirements for particular items of test gear. I doubt you will find any sort of catalog.
You may be able to cross reference the part numbers on the transformers to see what HP equipment they came from. After that, you would have to consult the manual for the specific piece of HP gear and estimate the transformer capability from the likely power requirements of that particular piece of equipment.
Good Luck,
Jim T.
KB6GM
PostPosted: Feb Sun 04, 2018 12:10 am
Part numbers? I have access to some DoD data, but part numbers are required.
Too many to list?
Brian
