It is currently Dec Sun 16, 2018 2:01 pm
 Post subject: Shielded Film/Foil/Paper Capacitors (with three lead wires)
PostPosted: Feb Sun 25, 2018 5:31 am
As I was recapping some radios I encountered some multi section paper capacitors.
I totally understand how to recap multi section electrolytic caps, but there is one thing unclear to me if the multi section cap is a paper cap.
I've Googled "multi section paper capacitors" left and right but I only find information on multi section electrolytic caps.
On the image we see a cap that I pulled out, labeled simply .025uF. I recapped as shown on the drawing over the picture.
If this was a multi section ceramic disc capacitor the recapping would be easy to understand. But this is a rolled up film cap, so should there be a third cap between A and B points?
I can best explain my dilemma with the following drawing.
If I think of this cap as a roll, I can clearly imagine an active area (colored yellow) between the A and the B foils. In fact, when I measure the discarded capacitor I also measure capacitance between the A and B leads. But the values on the old cap are very much off, so the measurements are inconclusive.
So, should there be a third cap between A and B points?
Thanks...
 Post subject: Re: Multi Section Paper Capacitors
PostPosted: Feb Sun 25, 2018 5:42 am
German? I think A & B is a normal cap, and the small lead off to the side is just a shield.
Another day older and deeper in debt.
PostPosted: Feb Sun 25, 2018 5:49 am
How does this part appear on the schematic?
One clue would be to measure the capacitance between all of the three possible pairs. ( one lead not connected for each measurement)
-Mark http://pixellany.com
PostPosted: Feb Sun 25, 2018 5:53 am
That's a European capacitor.
It really doesn't matter since their electrons work just like ours.
There are various ways of making multi-section paper caps.
One that has not been mentioned is splitting one foil at the middle with part going to each end lead.
The common lead (usually ground) goes to the other foil, which runs the full length of the cap.
PostPosted: Feb Sun 25, 2018 5:56 am
Oh, I see. So I recapped incorrectly. I guess I should just wrap a regular film cap in a foil and ground that foil.
You are correct. I am encountering those caps in three German radios.
It was unclear to me until marko said it was a shielded cap. Now I see the schematic shows a cap surrounded by a box drawn as dashed lines. What marko said makes sense now.
I do measure capacitance between all pairs, but the values are all over the place. I can't get consistent values between two caps that are supposed to be the same.
I guess at this point I'll go with marko's recommendation and just wrap a new film cap in a foil and shield it. Or are there any more elegant solutions?
Thanks...
PostPosted: Feb Sun 25, 2018 5:59 am
I didn't think of that. But I think between the schematic and what marko says, it's probably not a multi section film cap, after all.
PostPosted: Feb Sun 25, 2018 6:01 am
I haven't been in a german set lately (or any radios for that matter) but I remember seeing these in some I capped in the past. Usually only a couple spots, I guess low signal, HF, areas? I forget. Maybe post a schematic here, so we could see if a multi section would make sense, or if shielded is more logical.
I guess if you're extra curious you could try taking it apart too, that should reveal the secret.
PostPosted: Feb Sun 25, 2018 6:03 am
Here is how one of the schematics show three of those caps.
I guess it's like a cap inside its own grounded enclosure.
Good idea! I think I might just do that.
PostPosted: Feb Sun 25, 2018 6:17 am
jogging my memory a little, looking a few schematics, Maybe they used them more around the tone controls and low level audio parts.
in this schema: https://nohm.eu/schematics/Nordmende/Ca ... 6%20RG.png
you can see a couple on the grids of the two triodes in the audio portion (EABC80, etc). It's drawn a bit more clearly as a grounded shield there.
edit: I wrote gate instead of grid... my I'm getting rusty with this hollow state stuff!
PostPosted: Feb Sun 25, 2018 6:18 am
Mystery solved.
It's a cap wrapped in foil as a grounded enclosure.
Thanks....
PostPosted: Feb Sun 25, 2018 1:48 pm
Thanks...
I make them using braid for the shield, then shrink-fit on the outside.
PostPosted: Feb Sun 25, 2018 2:51 pm
Do you mean, to just strip some braided wire and shrink fit it?
I was thinking of using a self adhesive copper sheet and solder on a lead. If I can find the piece of copper sheet that I know I stashed somewhere.
PostPosted: Feb Sun 25, 2018 3:06 pm
If you can't find it, McMaster-Carr has it: https://www.mcmaster.com/#foil-tape/=1bq205x
They also have the same thing with an electrically conductive adhesive, but if you overlap the type above a little it will work just fine.
― R. A. Heinlein
PostPosted: Feb Sun 25, 2018 5:51 pm
Here! Done!
I flattened a scrap component lead wire and soldered to the copper shield. The copper shield is overlapping the capacitor's body (just like the old Germans did it) and I filled those cavities with epoxy (just like they did it).
After the shrink wrapping I took the time to write a label with the value .025u/630V and even wrote "shielded capacitor" on the label, so the next guy that'll be recapping won't have to ask the same question on a forum.
I also should edit the title, since this post is probably going to help someone in the future.
Thank you guys... (especially marko)...
