It is currently Jun Thu 21, 2018 9:19 am
 Post subject: Can Anyone ID these tubes?
PostPosted: Mar Fri 02, 2018 12:52 am
Found these in a box of tubes, but they had no identifying marks.
One is in a "99" envelope.
 Post subject: Re: Can Anyone ID these tubes?
PostPosted: Mar Fri 02, 2018 1:05 am
The second looks like a photodetector:
Some here:
http://www.sphere.bc.ca/test/photo-tubes.html#catalog
Scott.
PostPosted: Mar Fri 02, 2018 1:52 am
First one looks like a BH (full wave gas rectifier) but I only see two wires coming from the elements. Could be BR which is half wave but shape is usually different.
PostPosted: Mar Fri 02, 2018 3:38 am
1st one is almost certain to be a BH tube. Its viewed at an angle so you only see half of its inards.
2nd one, red sensitive phototube. Maybe a 868 or 918.
PostPosted: Mar Fri 02, 2018 6:59 am
You could expose them to some strong RF and they would light up with a purple glow.
I like things that light up, tubes, bulbs, LEDs, whatever, and things that make noise.
PostPosted: Mar Fri 02, 2018 2:28 pm
Thanks everyone.
PostPosted: Mar Sat 03, 2018 2:43 am
The 868 was used in RCA Photophone theatre sound reproducers, starting around 1929. Eventually, they came up with the 918, which was a drop-in replacement that had more output.
They ran with a 90 volt B+ supply, through a high value resistor or coupling transformer primary.
I have a box full of them downstairs somewhere, mostly "pulls".
