It is currently Sep Thu 20, 2018 9:44 pm
 Post subject: Test data for UV-201 Tubes
PostPosted: Mar Sat 03, 2018 12:07 am
How do you test UV-201's?
Dan
 Post subject: Re: Test data for UV-201 Tubes
PostPosted: Mar Sat 03, 2018 1:06 am
Dan
Test the same as an 01A. A UV201 without an "A" draws 1 amp filament current but otherwise will test as UV201A.
Due to short pins may have problems making contact with a tube tester socket?
PostPosted: Mar Sat 03, 2018 1:13 am
Dan,
Did you see my post in the rejuvenate topic? I fabricated an adapter for the short/long pin 4-pin tubes. It also allows for a live filament measurement. Some tube testers may not yield enough voltage vs the filament setting. Meaning, the line control pot/meter may tell lies. Measuring the 201 filament and getting it up to 5 volts will be important.
Do re-solder the pins...
20's fans would push the filaments up to get emission from the '01 no matter...
PostPosted: Mar Sat 03, 2018 1:33 am
Norm- Thanks for the info.
Chas - I did see your post. A socket saver I made and posted awhile ago works with short pin tubes also, a double win. I usually clean up the tube pins with scotchbrite pads to get good contact.
Thank you both!
Dan
