It is currently Sep Sun 23, 2018 12:01 pm
 Post subject: 7043 vacume digital display tubes
PostPosted: Mar Wed 07, 2018 7:33 pm
Going through small boxes, don't even know where these tubes came from, just stuff. Manufacture date 1948 RCA,# 7043 numerical display tubes. not miniature tubes. Any use or toss??
 Post subject: Re: 7043 vacume digital display tubes
PostPosted: Mar Wed 07, 2018 7:40 pm
Can you post a phot or two ?.
PostPosted: Mar Wed 07, 2018 8:14 pm
PostPosted: Mar Wed 07, 2018 8:28 pm
They are vacuum phototubes, not numerical display tubes. They may be of use to folks interested in light and physics.
Norman
PostPosted: Mar Thu 08, 2018 12:00 am
Do a google on them. They are cylindrical photocells which vary their resistance when illuminated. They do not light up themselves. Very interesting, unusual photocells that were used in the tone generator systems of Kimball organs. The organs used spinning disks with optical tracks on them, similar to sound tracks on movie film, to produce the various "voices." Multiple exciter lamps were located on the other side of the disks and lenses. When you pressed a key on the keyboard, it would turn on one or more lamps which would shine through the moving tracks, modulating the light. The photocells would convert the modulated light to an audio voltage.
Probably not of much use for anything else, but they could be of great interest to somebody who is restoring or maintaining an old Kimball. If you don't want them, I'd suggest advertising them in connection with Kimball organs and see where that leads.
http://lampes-et-tubes.info/pc/pc104.php
PostPosted: Mar Thu 08, 2018 12:10 am
They were also used in some 1960s-vintage De-icing trucks we had at one Naval air station. I had to buy a pair from.....sigh.....eBay to keep the trucks up. They sensed either flow or liquid level IIRC, and while we had a work-around, for the sake of 18 dollars (this was ~2005/2006), I popped for them to get the trucks full mission capable....only to find two burnt out bulbs as well. :cry:
Brian
PostPosted: Mar Thu 08, 2018 7:15 pm
I have some of those. I collect them because they are unusual.
PostPosted: Mar Sun 11, 2018 9:27 am
That's definitely a keeper, even if just for the rad factor. If you don't want them, hit me up if you haven't passed them off already.
