Page 1 of 1
[ 15 posts ] |
| Author |
SignatureSeriesOwner
Post subject: Cool Old Remote Posted: Jul Wed 06, 2011 4:06 pm |
| Member |
Joined: Sep Tue 09, 2008 4:31 am Posts: 2376 Location: Surry, VA
Got this in a box at an estate sale, I'm guessing mid 60's? as you press the button(s) down, a metal piece flies out and strikes an aluminum rod, which does the appropriate function. I don't have any real use for it, but would it be worth the trouble listing it on eBay, or should it just be something I put on one of the many shelves I have as a classic piece of Americana? I wish the remotes these days still looked as classy.
_________________ William D.
Saving America's acoustical history, one phonograph at a time..
| Top |
bgadow
Post subject: Re: Cool Old Remote Posted: Jul Wed 06, 2011 5:02 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3477 Location: Federalsburg, MD
Early to mid-70s. There were different versions, some with more buttons. It is a classy looking remote-Zenith always did know how to appeal to folks that way. I haven't checked to see what they are selling for right now; I have a few like this one but I don't think any are as clean as yours. For what it's worth, the TV this went to was one of the best built sets ever made anywhere.
| Top |
Post subject: Re: Cool Old Remote Posted: Jul Wed 06, 2011 5:13 pm |
| Member |
I quite like it, to be honest. I used a solution I have to turn the heavily yellowed Power button to it's original color (almost.) Probably should have let it soak another hour or two. The solution works great, I'm slowly turning every yellowed piece of plastic in this house white again.
I'm a bit surprised it could be a mid 70's model, I would have thought they would have gone to infared by then.
| Top |
RepairTech
Post subject: Re: Cool Old Remote Posted: Jul Wed 06, 2011 5:31 pm |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
SignatureSeriesOwner wrote: I quite like it, to be honest. I used a solution I have to turn the heavily yellowed Power button to it's original color (almost.) Probably should have let it soak another hour or two. The solution works great, I'm slowly turning every yellowed piece of plastic in this house white again.
I'm a bit surprised it could be a mid 70's model, I would have thought they would have gone to infared by then. Definitely 70's era. I've got an identical one with 4 push buttons..... the origin of the slang term "clicker" obviously came from these "tuning fork" style remotes. Magnavox used a bellows/whistle principal in their older remotes. Infrared remotes started showing up sometime around 1980.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
CaveRat
Post subject: Re: Cool Old Remote Posted: Jul Thu 07, 2011 1:27 am |
Back in those days you could sometimes change the channels or adjust volume by just rattling a set of keys if they happened to hit the same frequency as these audible remotes.
I remember seeing one, (forget what make) that used a little metal tube (whistle) and a bellows inside. When you pressed the button it released a puff of air through the tube and the high pitched whistle was picked up by a Piezo microphone element on the TV. No batteries required!
| Top |
RepairTech
Post subject: Re: Cool Old Remote Posted: Jul Thu 07, 2011 1:42 am |
| Member |
CaveRat wrote: Back in those days you could sometimes change the channels or adjust volume by just rattling a set of keys if they happened to hit the same frequency as these audible remotes.
I remember seeing one, (forget what make) that used a little metal tube (whistle) and a bellows inside. When you pressed the button it released a puff of air through the tube and the high pitched whistle was picked up by a Piezo microphone element on the TV. No batteries required! I mentioned the "make" in my previous post.
| Top |
ledsa
Post subject: Re: Cool Old Remote Posted: Jul Sun 10, 2011 2:59 am |
Joined: Aug Fri 03, 2007 1:06 am Posts: 112 Location: Upstate South Carolina
Quote: I quite like it, to be honest. I used a solution I have to turn the heavily yellowed Power button to it's original color (almost.) Probably should have let it soak another hour or two. The solution works great, I'm slowly turning every yellowed piece of plastic in this house white again.
I am curious to know what this solution is that whitens yellowed plastic. Quote:
| Top |
danemodsandy
Post subject: Re: Cool Old Remote Posted: Jul Sun 10, 2011 3:38 am |
| Member |
Joined: Dec Sat 12, 2009 5:44 pm Posts: 566 Location: Waterloo, Iowa
| Top |
Post subject: Re: Cool Old Remote Posted: Jul Sun 10, 2011 4:38 am |
| Member |
^ That's the link.
Basically, if you have smaller objects, you'll need a clear (very important) container, some 15-20% Hydrogen Peroxide (40 Volume from Sally Beauty Supply does it) and some Oxy powder. Generic, OxyClean, it doesn't matter.
For a gel, you'll need that, Xanthan gum, and Glycerine. Works well on larger objects.
| Top |
Arran
Post subject: Re: Cool Old Remote Posted: Jul Sun 10, 2011 4:47 am |
Joined: Apr Sun 08, 2007 6:47 am Posts: 4374 Location: British Columbia
I may have a use for one of those ultrasonic Zenith remotes soon, I have my eye on a '70s Zenith but I'm not sure of the year. It's one of those white console ones on a pedestal that looks like it came from "Space 1999" or a "Clockwork Orange". Regards Arran
| Top |
Electronic Memory
Post subject: Re: Cool Old Remote Posted: Jul Mon 11, 2011 3:08 am |
Joined: Nov Thu 11, 2010 6:03 pm Posts: 397 Location: Pewaukee, WI
I believe you are desrribing a Zenith Avante console.
Tom C.
| Top |
Arran
Post subject: Re: Cool Old Remote Posted: Jul Mon 11, 2011 3:12 am |
Electronic Memory wrote: I believe you are desrribing a Zenith Avante console.
Tom C. I couldn't find a model name on it anywhere, just a number, but I'm sort of interested in getting it if I can find a place for it. It isn't really an antique but it is interesting and reasonably well made, sort of a novelty if anything. Regards Arran
| Top |
jimmc
Post subject: Re: Cool Old Remote Posted: Jul Tue 12, 2011 1:37 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1044 Location: Phoenix, Arizona
Back in my mispent youth my neighbor had one of those Zenith sets with that mechanical remote. When you push a button it sounds an ultrasonic note higher in frequency than human hearing. I had a dog whistle and I could sit near the window of my den which was near the window of the neighbors den and tweak the pitch of my whistle and hear the channel change on the neighbors set. Don't call me captain Crunch however  Jim
| Top |
Electronic Memory
Post subject: Re: Cool Old Remote Posted: Jul Tue 12, 2011 1:44 am |
Oh capt'n, my capt'n! Tom C.
| Top |
ggregg
Post subject: Re: Cool Old Remote Posted: Jul Wed 13, 2011 4:02 am |
Joined: Aug Sun 01, 2010 1:12 am Posts: 5230 Location: Minnesota
| Top |
