It is currently May Fri 25, 2018 9:31 pm
Post New Topic Post Reply  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: RCA 8-PT-7010 Coming
PostPosted: Aug Tue 02, 2011 3:31 pm
Hi,
I just picked up an RCA 8-PT-7010 on ebay. The seller said all he coould get out of it was some static sound. It was shipped out today, and I only live 1 state from the seller. I hope to have it by Thurs, and I can't wait to get started on it.
 Post subject: Re: RCA 8-PT-7010 Coming
PostPosted: Aug Tue 02, 2011 5:54 pm
This article has some restoration notes on that model:
http://antiqueradio.org/rca16.htm
Enjoy!
Phil's Old Radios
PostPosted: Aug Tue 02, 2011 6:32 pm
Phil, Thanks for the article. I just skimmed over it and really enjoyed it. When my set comes in, I'm going to thoroughly read it again detail by detail, so I hopefully won't make any mistakes. I'm glad you put in disassembly instructions too as well as the issue about the 6CM7 and 6CG7 tube. When my set comes in, I'll see what tube my set has. I just ordered a Sams for mine.
Doug
PostPosted: Aug Tue 02, 2011 7:20 pm
thi is a real nice tv, I have two of them, I restored one and one for parts. it is a compact tv with a power transformer and kind of a bear to work on but they work well. I used phils info from his web site to restore mine and a few others that he has restored on his site. good luck. Bill.
PostPosted: Aug Tue 02, 2011 11:46 pm
http://www.mediafire.com/dholland
And the service manual for your reading pleasure....
Cheers....
David
PostPosted: Aug Tue 02, 2011 11:54 pm
Hey, thanks for the advice and manual. I am not the most meticulous person in the world with a soldering gun, so I'll have to be extra careful on this set since it is so compact. I'd rather work on a much larger chasis, but I'll just take my time. About 20 yrs ago I bought a Sony 8-301W at an antique shop which worked a little but needed a good restoration. I've never attempted it due to the compact size. Plus, everything I've ever tried to work on solid state, I've blown up!
PostPosted: Aug Wed 03, 2011 2:40 am
they are really not that bad, very well engineered, and have a very good sound as well.
PostPosted: Aug Wed 03, 2011 3:02 pm
Hi, the set arrived about an hr ago. Since the seller said all he could get was some static sound, I went ahead and plugged it in. I got nothing. I had already printed out the servicer manual (Thanks David) and just printed out Phil's link (thanks Phil) which I followed to a T about disassembly. Actually, it doesn't look as hard as I first assumed. I'm getting ready to start replacing the electrolytics, then I will go from there.
PostPosted: Aug Wed 03, 2011 3:07 pm
Let us know how it goes.....
I've got one sitting on the shelf that (allegedly) loses HV/picture after it warms up. Haven't gotten around to looking at it....
David
PostPosted: Aug Wed 03, 2011 5:14 pm
Well I got into the set today. I replaced one electrolytic and several paper caps. My tube checker said the 1V2 was bad, so I replaced it. Still nothing. Then I happened to turn the ser over on it's side and noticed one of the tuner 6U8 tubes was missing. Imagine that! Putting in a 6U8 gave me very weak & distorted audio with the volume control about 1/3-1/2 way up. Turning it up further makes the sound disappear alltogether. Still no raster yet.
PostPosted: Aug Wed 03, 2011 6:18 pm
I restuffed the old can (very little space) mutisection cap.
PostPosted: Aug Wed 03, 2011 11:16 pm
I did learn one lesson already on this set. Markings on paper electrolytics do rub off with age. I one I replaced looked like it said 5mfd @ 50V. The voltage marking was wearing off. I was all set to put in a 4.7 @50v when something said "power up the set and check the voltage across the old unit." I did and got about 290V. Obviously the old unit had said 450V instead of 50V.
PostPosted: Aug Fri 05, 2011 12:03 am
Some success: I have replaced about 3/4 of the paper caps. That gave me perfect audio but still no raster. I then replaced the 2nd tubular electrolytic, a 60mfd @ 160V. That brought it back to life. I now have a sharp, almost perfect pic. The only problem is the vertical hold is somewhat unstable. I only left it on for about a min because I haven't replaced the main electrolytic can yet. That's coming next as well as the rest of the paper caps. From what I've see so far, this set impresses me. Good sound and pic in such a small set, and it's been relatively easy to work on too.
PostPosted: Aug Fri 05, 2011 1:30 am
:? Are we talking about the same set here??
I've had bad luck with these sets. Not great reception, poor contrast, and, fair volume at best...
May I see a picture of it playing?
Thanks.
Bill Cahill
PostPosted: Aug Fri 05, 2011 1:26 pm
they are great little sets, the one I worked on was easy, GREAT sound, perhaps the use of a ratio detector rather than a gated beam detector. Does the vert want to roll one way (like you are out of adj) or can you roll it both ways just not a solid lock? if its not a solid lock but you can roll it both ways I would look a the integrater network which I think is R153/C151 and C154. if it want to roll one way R151. C156 looks like a stressed cap as well. if you have a scope wave form 7 should tell you if you are getting a good vert sync output. V102 and V103 would be suspect.
PostPosted: Aug Fri 05, 2011 6:43 pm
Update: I've gotten 3 of the 4 sections replaced in the main electrolytic can as well as almost all of the paper caps. Vertical hold now impossible to lock in pic. The .022 of plate of 6CG7, .033 off grid has been replaced at 1 time with orange drops. i guess they're still good. I replaced 2 paper capacitors (.0056, .022) and 2 resistors 39K and 100K in the vertical hold circut but didn't help. I also tried another 6CG7 as well. Voltages on the tube are ok. I'll keep digging
Bill, I took a pic of the set out of the cabinet playing, but I think my cell phone is dying as it won't let my upload it to my computer. I'll keep trying and eventually get you a pic.
Doug
PostPosted: Aug Fri 05, 2011 7:02 pm
I dont think those caps are the ones in the intgrater check C151,154 and R153. does it roll both ways with the vert hold?
PostPosted: Aug Fri 05, 2011 11:19 pm
Yes, it does roll both ways. Just can't get it to lock in.
PostPosted: Aug Sat 06, 2011 12:36 am
Sync circuit problem. Not vertical.
Bill Cahill
PostPosted: Aug Sat 06, 2011 1:04 am
Yes, possibly a weak/missing sync pulse. If it rolls both directions but won't lock that is usually proof that the oscillator and output stages are working properly, but the sync pulse either isn't getting there or isn't strong enough to lock the oscillator.
The next step would be to look at the vertical sync pulse with a scope and see what is going on. That will narrow down where the problem is.
Post New Topic Post Reply  [ 36 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page 1, 2  Next
Users browsing this forum: oldmannewtrick and 3 guests
