Page 1 of 1
[ 11 posts ] |
| Author |
hi_volt
Post subject: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 4:31 am |
| Member |
Joined: Oct Mon 03, 2011 5:33 am Posts: 294 Location: Tucson, Arizona
| Top |
Kevin Kuehn
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 8:39 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3126 Location: WI
Very nice! And probably not too often seen cabinet style.
| Top |
Ampico-kid
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 3:42 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 105 Location: Harpers Ferry, WV 25425
Great looking set!! Hope your crt is good. From your pictures the cabinet doesn't look bad at all. A little elbow grease and some minor touch up and it should look great. Hopefully it'll be an easy restoration.
Can't wait to see some screen shots once it's been completed.
Best of luck with it. Bob
| Top |
Clark, K9OA
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 6:05 pm |
Joined: Aug Mon 16, 2010 6:58 pm Posts: 148 Location: Madison, WI
Nice find! The 700 mile trip shows that you have contracted full-blown vintage TV itis My CTC-7 "Abington" is also missing the "D" on the deluxe emblem, and I've seen several others with the same problem. Maybe it's time to look into having repros made... I hope the CRT is good. Good luck! -Clark
| Top |
Ampico-kid
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 6:20 pm |
Clark, K9OA wrote: My CTC-7 "Abington" is also missing the "D" on the deluxe emblem, and I've seen several others with the same problem. Maybe it's time to look into having repros made...
Yes you're absolutely right. I have a CTC-7 Grenoble, and the Deluxe "D" is missing on mine....hmmmm...sounds like we're onto something here. Bob
| Top |
philsoldradios
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Jan Mon 30, 2012 7:39 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3707 Location: Woodinville, WA USA
A flat emblem like that is straightforward to reproduce if you have a complete original to serve as a model for the mold. If your original is incomplete and you're good at modeling, you could fill in the missing part with clay and then make the mold. At http://antiqueradio.org/EmersonSnowWhite247.htm you can see how I cast a repro of an Emerson Snow White radio panel. To give a metallic color (and heft), you can mix metal powder into the casting resin. I have a couple of repro parts made that way, and they're indistinguishable from the originals. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
hi_volt
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Feb Wed 01, 2012 2:43 am |
| Member |
Got home from work on time today for a change, and tested the original 21AXP22A picture tube. No shorts, and all three guns well into the "Good" green emissions range. Should be a good playing set.
| Top |
Tom Schulz
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Feb Wed 01, 2012 2:55 am |
| Member |
Joined: Mar Sun 01, 2009 10:27 pm Posts: 2915 Location: Ann Arbor, MI
hi_volt wrote: Got home from work on time today for a change How did you manage to do that? Inquiring minds want to know!
_________________ Tom
| Top |
Electronic Memory
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Feb Wed 01, 2012 5:10 am |
Joined: Nov Thu 11, 2010 6:03 pm Posts: 397 Location: Pewaukee, WI
Tom Schulz wrote: hi_volt wrote: Got home from work on time today for a change How did you manage to do that? Inquiring minds want to know! Perhaps he is the one that stole my teleportation device! When you tested your 21AXP22 did it have good cutoff response? And did you do it in a dimly lit room and watch the neck of the tube? On mine the cutoff meter adjustment was an all or nothing kind of thing. Basically on my B&K CRT tester I have to tweak the cutoff control until the meter needle moves two increments on the meter scale, but on my 12AXP22 I could not get it to move only two increments.....It would either remain stationary or shoot up to way beyond two divisions with no range in between. The neck of my tube also glowed purple which is an indication that the tube has a leak and air has gotten in (which ruins the usability of tube). Mine is shot, and I gather that these tubes have a tendency to go to air if you see any of these issues in your tube it is a bad sign.
| Top |
hi_volt
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Feb Wed 01, 2012 1:49 pm |
| Member |
No problems that I could see. I did not see any kind of purple glow when I looked at the filaments. Cutoff response was good.
| Top |
akent36
Post subject: Re: Another New Acquisition....CTC5 "The Chandler" Posted: Feb Sun 05, 2012 1:45 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 765 Location: Rockford IL USA
Great 50's styling.
Purple glow from an air tube would usually be between the grids.
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
