It is currently Feb Thu 21, 2019 10:34 am
 Post subject: Sony watchman AV input
PostPosted: Aug Sun 02, 2015 7:23 am
I have a Sony watchman model FD-20A, there is a jack on the side labeled video in. It is the size of a standard 1/8" jack, however when I plug my RCA to 1/8" splitter cord into it all I get is video and no sound. Do I need a special cord, or is this input only for video and not sound, and if so why would the designer do that?
Caretaker of Portable Tube Radios
 Post subject: Re: Sony watchman AV input
PostPosted: Aug Sun 02, 2015 12:33 pm
A raw video signal does not contain audio. Perhaps the input jack is a "stereo" version with, for example, video on the tip connection and audio on the ring connection. Just a thought.
PostPosted: Aug Sun 02, 2015 1:57 pm
I have several of these but can't put my finger on them right this minute. I suspect that it is just a jack for video only, not video and audio. If it were both, I really think it would be labeled the same. I will see what I can find later today.
A screen shot from the auction site...
PostPosted: Aug Sun 02, 2015 8:53 pm
Why would Sony put a video only jack on this?
PostPosted: Aug Sun 02, 2015 11:24 pm
It's probably composite video only, for use as a monitor I suppose. It would surely be labeled A/V input if it were both.
PostPosted: Aug Sun 02, 2015 11:44 pm
A monitor would be my guess as well, and that feature was apparently somewhat short lived. I have an FD-40A, and it doesn't have a video input jack.
PostPosted: Aug Mon 03, 2015 12:13 am
It's labeled Audio/Video In on my FDL-310.
Handyman of the apocalypse
PostPosted: Aug Tue 04, 2015 6:47 am
The FD-40A I used to have had an RCA-looking jack on the side which was labeled A/V IN. I found a picture of the mating plug meant to fit said connector, and it basically looks like a regular RCA plug with a 2-conductor 1/8" plug where the center pin would normally be. Here's a picture of the adaptor meant to fit said plug:
(Click to enlarge)
I'm pretty sure the jack on the FD-20A is, as indicated, video only. No idea exactly why they decided to do this, but they did. They also included an antenna in jack on the top, at the least.
Adam Vaughn
Visit my page at
PostPosted: Aug Tue 04, 2015 7:48 am
(Click to enlarge)
Thanks for the input A.V.! :lol:
PostPosted: Aug Wed 05, 2015 2:29 am
Hello guys,
yes as Adam Vaughn pointed out that the same jack on my sony 4in b/w and mine has aux antenna to.
I also have a smaller sony to
PostPosted: Aug Wed 05, 2015 1:52 pm
I have a Zenith BT044S that looks to have the same connector as Adam is showing.
Not sure how it is related to a Sony, as it claims to be made in Mexico, which Zenith indeed had a factory down there.
Perhaps the same CRT?
PostPosted: Aug Wed 05, 2015 7:56 pm
I have a Sony 8mm digital video camera and it has an 1/8" jack but it's labeled A/V input, the connector is Red. White Yellow RCA jacks to 1/8" plug with an extra contact for the video.
PostPosted: Aug Thu 06, 2015 6:58 am
It wouldn't surprise me if Sony OEMed the set for Zenith, as Sony also rebranded their Betamax VCRs for them. I have a Zenith "Video Director" VR-9000W which is little more than a Sony SL-5400 with different trim. More on Zenith's rebranding of Sony Betamax VCRs can be found here.
Other companies also made OEM stuff for Zenith; a friend of mine has a Zenith VP-2000 Selectavision CED player which was made for them by RCA. And according to this page, JVC made the first VHS VCRs sold under the Zenith name after they abandoned the Betamax format in the mid '80s.
Adam Vaughn
Visit my page at
PostPosted: Aug Thu 06, 2015 8:10 am
HelloAdam Vaughn ,
yes my repairshop sold and did warrenty work on Zenith brand products till the end spanning like 40 plus years Also rca and sony warrenty I miss those days at the shop .
that feels like a life time ago
PostPosted: Aug Fri 07, 2015 1:18 am
Yeah, I worked for a Zenith dealer first part time between August 1984 to May 1985, then full time between March 1986 and May 1998.
I'm quite familiar with the Sony made Betamax Zeniths and the JVC made VHS Zeniths, then around 1990, they transitioned to Goldstar made VHS decks.... which were a mess...
They were clearly marked "Made in Japan" or Korea.
This TV is marked Mexico, so I suppose they could have bought the components from Sony and assembled them in Reynosa, but why ad the extra step?
Anyhow, kinda getting off topic here, so I'll stop now.
Post New Topic Post Reply  [ 15 posts ]  Moderators: 7jp4-guy, Mr. Detrola
