It is currently Feb Sun 17, 2019 2:27 am
Post New Topic Post Reply  [ 107 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Zenith H2447R 19" Porthole TV
PostPosted: Nov Sun 12, 2017 10:58 pm
cwmoser wrote:
Though I'm not currently working on a TV project, I do find what you are posting
very informative. You most likely have a lot of us reading your posts.
Impressive restoration work you are doing.
Thank you.
Crist
PostPosted: Nov Sun 12, 2017 10:59 pm
When I recap a chassis, I usually replace the resistors, and mica caps too. I get my 1W resistors from Mouser and they only cost 4 cents each, so I change them out. Of the past chassis I've done I see that at least 50% of the resistors are out of tolerance, 25% are very close, and 25% are within tolerance.
I'll cover what I do on a terminal strip. Tube sockets are treated the same. The first thing I do is take several pictures of the terminal strip. Then I draw out the terminals and what is connected to them. I also add where the other end is terminated. I then double check my drawing.
I then cut off the components and leave about 1/4 long leads still attached to the terminals. Then I use my solder sucker and solder wick, I clean off the terminal and remove the cut off leads. Then if a wire/wires are attached to the terminal, I clean it up and put the wire as far down the terminal as possible. I trim the leads to wrap around the terminal but not long enough to go back over the hole in the terminal. This keeps the hole opened up for additional components. When the wire/wires are set on the terminal, I then solder them to the terminal using as little solder as possible. I do this to be sure that the wire/wires are soldered to the terminal because when components are added and with the wire/wires being down low, they might be missed when adding solder. Also this small amount of solder holds the wire in place.
I then try to add the components in a logical manner. Once the terminal is fully populated, I solder it and then clean off the flux with an acid brush cut down to about 1/4 to 3/8 inch and acetone.
Crist
PostPosted: Nov Mon 13, 2017 4:26 am
I did a terminal strip located near the front of the chassis. It was pretty much self contained and consisted of just a few parts.
File comment: During the removal of the old parts, I noticed that there was that yellow CAD plating residue on parts of the terminal strip.
File comment: What I do to clean off that residue is I use CLR cut 50/50 with water. I brushed on a little with a cut down acid brush to about 1/2 inch long. I then "scrub" the area with the acid brush. Then I mop up the area with paper towels, Q-Tips, and alcohol. The residue comes off very easy this way.
File comment: I then replaced the components and cleaned off the flux, and I'm done.
Since this picture was taken, I added some more solder to the lower ground terminal.
Crist
PostPosted: Nov Mon 13, 2017 12:52 pm
Your comment ...
"When I recap a chassis, I usually replace the resistors, and mica caps too. I get my 1W resistors from Mouser and they only cost 4 cents each, so I change them out. Of the past chassis I've done I see that at least 50% of the resistors are out of tolerance, 25% are very close, and 25% are within tolerance.
I then cut off the components and leave about 1/4 long leads still attached to the terminals. Then I use my solder sucker and solder wick, I clean off the terminal and remove the cut off leads. Then if a wire/wires are attached to the terminal, I clean it up and put the wire as far down the terminal as possible. I trim the leads to wrap around the terminal but not long enough to go back over the hole in the terminal. This keeps the hole opened up for additional components. When the wire/wires are set on the terminal, I then solder them to the terminal using as little solder as possible. I do this to be sure that the wire/wires are soldered to the terminal because when components are added and with the wire/wires being down low, they might be missed when adding solder. Also this small amount of solder holds the wire in place."
... Sounds time consuming but I think in the long run it saves lot of troubleshooting and results in a better
restoration.
This is good advice for all of us experienced and especially novices who attempt to restore a
Television for the first time especially those that do not have great TV troubleshooting experience.
Basically its all about being methodical and learning more about electrical restoration.
Whats the moral to the story about the Tortoise and the Hare"?
PostPosted: Nov Mon 13, 2017 6:58 pm
Yeah, saves in a lot of troubleshooting and most importantly a better restoration.
Crist
PostPosted: Nov Mon 13, 2017 7:00 pm
Moving to the upper part of the chassis I decided to do the terminal strip near T3.
Pretty routine and nothing special to report except I had to lengthen a lead on R84 a 100 Ohm resistor. What I do is trim the one side to about 1/4 inch length. I then use some 22awg bus wire and attach it to the trimmed lead using the coil method. I then figure out how long the lead needs to be and slide a piece of 1/16 inch heat shrink tubing down to the coil. I then shrink the tubing and then use a 1/4 inch long piece of 1/8 heat shrink tubing to cover up the coil.
Crist
PostPosted: Nov Tue 14, 2017 6:21 am
Some more work around V9.
Then some around V14.
And finally an over all picture of my progress.
Crist
PostPosted: Nov Thu 16, 2017 4:41 am
My high voltage wire came in so I finished the Flyback wiring. I decided to use some new 20Kv 22awg wire. I've used this stuff before and it has worked well for me. The working H.V. is about 12 to 14Kv.
I used some heat shrink to increase the diameter of the wire and to provide some extra abrasion resistance as it passes through the then guides. I then soldered it to the 1B3GT tube socket and used several layers of heat shrink tubing to provide some extra strain relief on the wires as they go into the tube socket. I then used some lacing cord to tie the wires together before they go into the tube socket shell.
I also used some of this wire for the plate cap wire for both 6BQ6GT and the 1B3GT tubes. I'll terminate the CRT HV lead during the dry fit phase.
Crist
PostPosted: Nov Fri 17, 2017 2:57 am
OK guys, I have some questions for the disc capacitors in this TV. I know they should be good, but I tested one and it was 50% high. So I'm thinking that maybe I'll replace them. There are only 10 of them.
My question is what do I use to replace them? I know I need ceramic disc and I'm thinking of getting 1KV type. I know there are by-pass and coupling caps. Do I get COG, NPO, Z5U, Y5P, etc?
Below is a simple chart I made up that shows the SAMS parts list and the cross for each size cap. Also the Item Number of each cap. I checked the old Allied Catalog archive but they don't really list the specs for those caps.
Any help would be appreciated.
Crist
PostPosted: Nov Fri 17, 2017 4:32 am
I have finished the main chassis except for the IF Strip.
We, the VRPS of Dallas, has our annual convention this weekend so there will be very little work and posting on my progress.
Crist
PostPosted: Nov Fri 17, 2017 4:34 am
That is quite likely within spec for a ceramic cap. Some common tolerances are -20%,+40% -20%,+50% -20%,+80% -0%,+100%
Both COG & NPO mean that the capacitance should not vary much with temperature. That should be OK but probably not what was used. Z5U means a temperature range of +10 degrees C to +85 degrees C with a capacitance variation of -56% to +22% over that range. Y5P means a temperature range of -30 degrees C to +85 degrees C with a capacitance variation of Plus or minus 10%. Probably Y5P is the thing to use.
PostPosted: Nov Sat 18, 2017 12:03 am
That Y5P rating would certainly be better than anything they originally installed for bypass caps.
Mark Nelson
tv-boxes.com
PostPosted: Nov Tue 21, 2017 6:35 am
Thanks guys for that info on the disc caps.
Crist
PostPosted: Nov Tue 21, 2017 6:36 am
During this weekend swap meet at our annual convention, I managed to get a few "donor" E-Caps for C4. This E-Cap is the smaller diameter kind.
I restuffed it basically the same way as the others. I use some R/C wing tube that I had after building a model. This stuff works great. I kept the caps out of the sleeve because they put a slight pressure on the sleeve and I thought it would deform the round sleeve. I haven't cleaned out the cans yet.
Crist
PostPosted: Nov Wed 22, 2017 5:28 am
The bottom side of the chassis is done. Every resistor, film cap, electrolytic, disc, and mica cap was replaced. Now on to the topside. The HV cage, tuner, yoke, etc.
Crist
PostPosted: Nov Thu 23, 2017 12:00 am
I replaced all of the resistors in the tuner today. 3 of them were a bit tough. I relied on the coil method for those 3 and a few other places. I cleaned the tuner assembly and then replaced the resistors. I then used De-Oxit and a business card to clean the fingers where the tuning strips slide through.
As a side note the average the resistors were 23% from their nominal resistance. The lowest was 3% and the highest was 62%. Of the 9 resistors replaced, 5 were way out of tolerance, 2 were 12% (just out of tolerance), and 2 were 3% (well within tolerance). Pretty close to what I've seen through the 6 chassis I've restored. Where at least 50% were out of tolerance. 25% were just out of tolerance, and 25% were with in tolerance.
Crist
PostPosted: Nov Sat 25, 2017 1:06 am
On to the turret. This turret is massive and very well built. First a photo 'walk around".
File comment: Here it is just removed from the chassis with the outboard cover removed.
File comment: The aft (motor driven end), if so equipped.
File comment: Looking at the side that faces to picture tube.
File comment: This is the side that faces forward. It also has the oscillator adjustment tool and drive gear.
File comment: Close up of the front end.
Crist
PostPosted: Nov Sat 25, 2017 1:13 am
More turret pictures.
File comment: A close up of the detent mechanism. Another indication of the quality of this TV.
File comment: The aft end ball race adjuster. The turret is suspended by 2 ball bearings. The front end uses a race and 9 "free range" ball bearings, while the aft end uses a thrust bearing. The aft end race can be adjusted in or out to get all the "play" out yet still spin freely.
File comment: The front end race.
File comment: The aft thrust bearing and the 9 balls for the front race.
File comment: A close up of the front shaft where the balls ride.
File comment: A close up of the aft section where the thrust bearing rides.
File comment: I took this picture to "locate" the actual strip according to the number stamped into the turret.
Crist
PostPosted: Nov Sat 25, 2017 1:17 am
I removed each strip and then I cleaned all the parts and removed some light rust from the inside of the cage. The strips will be dealt with later.
The turret is copper plated steel and while cleaning and polishing it, I rubbed through the plating. My idea was to clear coat the polished copper plated turret to prevent it from tarnishing. Then I remembered that I had some Rust-Oleum Metalic Copper spray paint. A couple of quick coats and we are in business.
File comment: Here is a picture of the aft end where I masked off the thrust bearing race and the new paint. Not much difference. The turret looks very good painted.
File comment: Here is a picture of the turret installed into the cage and the free end play adjusted along with the drive gear installed. The turret spins very nicely with no end play.
File comment: The end play is taken up by screwing in on the aft ball race. When adjusted just right, the large nut is then tightened to "lock" the assembly. While this might lock the assembly, there was some greenish looking liquid applied to the lock nut and race to prevent it from coming loose. I used some Super Corona Dope that I had to lock the assembly down.
File comment: A close up of the front end after assembly.
Crist
PostPosted: Nov Sat 25, 2017 3:53 am
Looking at the numbers on the end of the turret, it looks like the channel strips are arranged every other channel starting at 2 and then after 13 start over again with 3. Yet the channel selector knob shows the numbers in order. How does this work?
Locktite makes something called thread locker. But that is not what would have been used in this set. I also seem to remember that there was something called glyptol. But I think that that was red.
Post New Topic Post Reply  [ 107 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Google [Bot], philsoldradios and 2 guests
