It is currently Dec Wed 19, 2018 5:07 pm
 Post subject: crt coating
PostPosted: Jan Tue 23, 2018 4:22 am
I have crt that is peeling the conductive finish what would be a good spray on finish to repair it?
 Post subject: Re: crt coating
PostPosted: Jan Tue 23, 2018 4:47 am
I have used Aerodag with success on a number of CRTs:
https://www.dbcindustrial.com/shop/item ... ODAG-16058
Pricey, but one aerosol can will recoat many CRTs.
Other people have recommended Grainger's Slip Plate:
https://www.grainger.com/product/SLIP-P ... cant-1WVK7
I also saw a recommendation for this MG Chemicals product:
https://www.amazon.com/MG-Chemicals-Con ... tal+ground
You don't need to strip the CRT bare before applying, but I'd remove all loose/flaky material and lightly clean with a soft brush and isopropyl alcohol to ensure good bonding.
Regards,
Phil's Old Radios
Last edited by philsoldradios on Jan Tue 23, 2018 4:56 am, edited 1 time in total.
PostPosted: Jan Tue 23, 2018 4:49 am
That paint is conductive graphite.
It's commonly called Aquadag.
Google is your friend!
Phil's answer is better.
PostPosted: Jan Tue 23, 2018 5:48 am
Thanks Phil
Post New Topic Post Reply  [ 4 posts ]  Moderators: 7jp4-guy, Mr. Detrola
